Bird half faded
Bird half faded
So on my '96 t/a the red firebird logo by the hatch lock is fading... and the "Trans Am" has completely disappeared. On ebay there's a guy selling some vinyl decals that are supposed to "fill in". Has anyone used decals? Is there a better method?
BTW I've used decals and all that crap before and they just suck! You have to be careful when washing it with a mit or w/e cause you can catch a corner and pull the decal up. Only decals I have no are the "ram air" on my hood. Plus IMO, decals make it look cheap.
You don't have to sand it to get the decal or whatever off.. You can just use rubbing compound and rub it off.. Comes off pretty easy, but still leaves the raised plastic part. This is where you'd have to wet sand and buff, however, if you don't, the raised letters and bird aren't that noticeable unless you're right up on it and looking for it...
Blakbird24 does great job if you can afford...
https://ls1tech.com/forums/showthrea...507&highlight=
Thanks Breathtaker... I might consider that. Removing the wording and bird isn't exactly what I was going for... quite the opposite actually. So that seems pretty viable.
here are the ones on my 95. they have been on there for about 4 years. IIRC i got them for ~ $10 from ebay
i went with gold. both of these photos were taken this summer with the sticker being ~ 4 years old
it was kind of a PITA to put them on since the ones i got you had to individually remove each letter and put them in place (the n and s are 1 sticker in Trans Am, but the rest are individual and the bird is about 6 pieces) i got it very close to its OEM location although if you get really really close (your nose almost touching the trunk lock) you can see where the bird is a little bit too far up from where it once was and you can faintly see its old outline, but no one has ever noticed it. i only noticed it myself after it was all dried. FWIW the easiest way to do it is to take off the panel (take off the taillights, and the panel comes right off) and take it into the house and do it over your kitchen sink (i used an old empty spray cleaner bottle filled with soap and water to put the decals on there.. you want to get it wet and then apply them so you can position them where you want them and then blow on them to dry them in place) it took me probably 30-45 mins to do the whole thing
my car does sit in the garage quite a bit, but i probably have put 25-30k miles on it since i added those decals
i dont remember who i got them from on there. i know i paid $2 extra for the gold
