NOT down shifting at WOT
LS1Tech Sponsor
Ok the answers are there some of them in the codes
the_" P0123 - Throttle Position (TP) Sensor Circuit High Voltage" would affect everything from line presure to shift points.
The other code is not trans related.
You need to repair the TPS circuit and then get a scanner on there and watch whats being comanded by the PCM in data gear wise.
__________________
well i sent the wire harness back to spear tech and he could not find anything wrong with the wireing. so now im waiting for it to come back in the mail. should be here weds. i just got a new MAF. i know what the TPS is but where is the TPS circuit located?
o so it should be all set then. speartech said that all the wires were right on and all work right. he tested the PCM and harness on his motor at the shop. so now im waiting for it to come in and i can install it.
so if the tranny is good and the wire harness is good then what could it be?? the answer is there some where!!!!!!
Moderator
Turn the key on, mat the pedal with a voltmeter
on the TPS output (to ground) and read it. If
you are over 4.75V it will set the code and some
trans functions will act funny.
