Decided on my H/C setup, need to pick what stall
Old 05-14-2009, 08:55 PM
Swift_01_z-28's Avatar
Default Decided on my H/C setup, need to pick what stall
Well, I have decided to go with a TSP 228R cam and some TSP ls6 stg 2.5 heads. I am wondering what stall speed I should go with. I asked a guy from tsp, but I haven't gotten an answer yet, so I just figured I would throw it up here.
I was thinking either a vig 3600 or a yank ss3600. I know they are both great converters, and I am leaning towards the vig, but I have heard that I should actually be looking at a yank ss4000.
I just want the stall that will work best with that combo. What would ya'll suggest?
BTW, if I can't get any answer from tsp soon, I may be changing my choice on cam and heads over to a futral cam and not 100% on the heads but I am certain I can find some somewhere.
Old 05-14-2009, 09:12 PM
406malibu's Avatar
damn dude... this is what the 5th thread asking about cam/heads/stall? just update your old threads.
Old 05-14-2009, 10:38 PM
Detoxx03's Avatar
I would go with the Yank SS3600. ^^^ LMAO
Old 05-15-2009, 06:30 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
Swift, I spoke with you before I think but you should give me a call and see what I have that can help compliment your combo.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 05-15-2009, 07:49 AM
Yank's Avatar
Call me if you like.
but I feel the SS4000 will be a great chioce for you as the Vig is under rated and will stall higher than stated 3600.
Dave
Old 05-15-2009, 09:35 AM
TXZ28LS1's Avatar
either one of those converters will be fine. im running a vig 3200 with my 230 cam and works well especially for a daily driver. another option is to check out circle D too. just dont go cheap on a converter.
Old 05-15-2009, 07:39 PM
Yeah I guess a got a little thread happy, my bad. I updated the old ones though. I just want to make sure that I get the right stall for that combination. I don't want to spend the money on everything and screw up on the converter. And believe me, I won't be going cheap on the stall.
Old 05-15-2009, 07:47 PM
Hopefully you guys will be understanding of the fact that this is the first sports car I have ever had and I really love this car and want it to run in tip top shape. I know I have started quite a few threads over my time on here about cams and stalls and such, but now I have finally decided what I am wanting to do, and am just trying my hardest to make sure this is going to be good for me and my car. I have heard that you should match your stall to your cam, so I'm just concerned. Hopefully ya'll can understand that.
Old 05-15-2009, 07:51 PM
01FbTaWs6's Avatar
no smaller then 4000. give greg at fti a call dude.....
Old 05-16-2009, 01:59 AM
DSkyles's Avatar
Are you going to be driving the car fairly often? I think the ss3600 should be fine. I drove my friend's bolt-on car with an ss4000 and it was a nightmare as far as driving it around. As far as performance he ran the same exact e.t. as another friend with the same mods except a fuddle 2800. I'm not sure how the 4000 would be with h/c but I think the 3600 would be good.
Old 05-16-2009, 08:59 AM
01FbTaWs6's Avatar
the reason you friends ss4000 was a nightmare is because its fairly loose. Get an FTI that stall to 4000 and is fairly tight, and it will drive pretty damn good on the street.
Old 05-16-2009, 01:06 PM
99Hawk262's Avatar
Interesting feedback on the SS4000....I ran one for a year and it was almost too tight for my tastes. Don't get me wrong, it was a great street/strip converter, but I wanted something a little looser with more topend. Between the two, I'd lean towards the SS4000....I ran an ST3500 before the SS4000 and streetability was almost identical. All the improvements were at WOT. Either way, you're making a great decision by going with Yank. They'll treat you good and give you an exceptional converter!
Old 05-18-2009, 12:11 PM
Outlawfireman's Avatar
Yank is a good brand, 4000 is gonna be pushin it for a DD. My 3800 is about at the max for what i like. Either way you go, it's deffinently gonna be faster.
Old 05-19-2009, 09:09 AM
allbaugh_04's Avatar
Thinking about going with the 4000 as well. Mine is in need of a rebuild, i can't remember if yank told me if i can choose which STR i want though. Not sure what to go with either.
Old 05-19-2009, 02:30 PM
bowtiebuilder's Avatar
Are these stalls you all speak of like progressive stalls? I haven't done much research on stalls, but if these are constant stalls, driving around at 4000 rpms seems kinda senseless...
Old 05-19-2009, 02:33 PM
01FbTaWs6's Avatar
depending on how tight the converter is. Like my 4400 stall will probably drive around at 2500 or so under 50% throttle. Once you lay the hammer down, itll stall to 4400
Old 05-19-2009, 03:08 PM
chrs1313's Avatar
Dave
what he said dont go 3600 like i did the first time around
Old 05-19-2009, 09:24 PM
1999BlueTA's Avatar
It's your car and in the end you will have to live with it one person's opinion of a stall being tight might be to loose to another opinions are just that they differ your best bet would be to ride in a few different sized stalled cars in your area if you can that will give you the best idea of which one you can live with and remember one companies stall might drive a little looser/tighter than the other. In my opinion don't go with anything less than 3600 I have an FTI 4000 its not bad at all to me I would'nt go with anthing less I love it and its what I recommend FTI, circled, vig, and yank are all great companies you can't go wrong with either but FTI is who I recommend give greg a call at FTI.
