What torque Convertor do i need
Old 06-19-2009, 05:54 PM
christrusler's Avatar
Default What torque Convertor do i need
I have a 2000 Z28 A4.
Besides headers, exhaust, it's pretty much stock and a daily driver. I'm having the transmission rebuilt and i'm going to get a new torque convertor. Which one do i need to get ? I'd like it to be close to stock, but maybe something to make it a little quicker.
Please help
Thanks
Old 06-19-2009, 11:58 PM
dnkynrbk's Avatar
Man from my expericence go with a 3200 stall no more I had a heads cam spray in my old set up in my sig and had a 3500 stall it was nice. no higher for street. But from a vendor on here do not buy junk esp a TCI I have had friends get those and there quality has went down. Talk to FRANK @PerfromaBuilt
Old 06-20-2009, 07:21 AM
Circle-D's Avatar
We have our 11" 3200 that sounds perfect for your application. Very affordable - only $375 for tech members. Great street manors and the 3200 stall will make a noticeable difference in performance. It should knock of .3-.4 in the 1/4 mile with almost no loss of MPG and street manors.
Chris
Old 06-20-2009, 07:40 AM
FLT
FLT's Avatar
Yank, Circle D or PI would be the people to contact IMO. As mentioned above do not buy a low budget converter or you will be sorry. Vince
Old 06-20-2009, 09:24 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
A 3600 would be the minimum I would sugest as they can be built to drive great and reduce et by.6-.8 tenths. You could put in a 3200 but you will not see the performance gain you will with a 3600.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 06-20-2009, 09:32 AM
TXZ28LS1's Avatar
i have a vig 3200 and its perfect for driving around and still getting the performance you want and it drives damn near stock which is what i wanted. i would say that a 3600 would be the biggest i would go. but like everybody else said, do not go cheap on a converter. get a good quality converter.
Old 06-20-2009, 09:47 AM
Yank's Avatar
take a look at our converter guide it will help in your choice on converters
www.converter.cc
All YANK Converters are reated to true stall for the car/truck model as listed
Old 06-20-2009, 12:08 PM
dnkynrbk's Avatar
sounds like you have some great advice. you cant go wrong with these guys on here.
Old 06-20-2009, 01:19 PM
angel71rs's Avatar
Depending on how "close to stock" you want, consider the converter mentioned here: http://forums.corvetteforum.com/c5-t...-da-floor.html
Old 06-20-2009, 02:37 PM
KameleonTransAm's Avatar
Hmm, that is interesting. I've never heard of anyone using the astro van converter before...
Old 06-20-2009, 08:32 PM
if i wanted to go back to a regular stock convertor, what are the specs?
Old 06-21-2009, 08:53 AM
Yank's Avatar
Same as an S10 converter ( non brazed with a weak clutch)but it will not fit an F-Boby 4L60-E trans
Old 06-21-2009, 06:14 PM
LuckySpencer007's Avatar
Chris
Really? wow i will have to look into that that is a great price. Do you think that stall and a level 2 performabuilt on a lightly modded formula would be a good combo? Maybe a max 100 shot.
SORRY FOR THE
Old 06-21-2009, 09:39 PM
JScamaro's Avatar
If you don't go to the track much and drive in the city with heavy traffic I would go with a 3200 stall converter.
It can be very annoying when driving in stop and go traffic or going uphill with the converter unlocked.
Old 06-22-2009, 07:55 AM
Circle-D's Avatar
The stock converter is a 300MM -12" 1500-1700 stall. I would not suggest this, even for a DD. THe 11" I mentioned is a great improvement over stock and is very affordable. It is not a very high stall converter so it will still drive great. Please call for any questions.
713-895-8834
Chris
Old 06-22-2009, 09:04 AM
SUNSET Z28's Avatar
get a yank ss 3200 i just put one in when i swapped in my performabuilt lvl 2 trans and it has made the most improvement over anything else ive done to the car plus frank and dave are great guys to deal with just my 2 cents
Old 06-23-2009, 04:41 PM
This is what the shop is going to replace...
Master kit, seals, gaskets, steel clutch etc
Commerical clutch pack
2/4band
Heavy duty accumulators
input sprag
pump bushing
case bushing
hardened pump rotor veins
and 2015 convertor
It's a bench build for $650
Does this sound right? This shop was about $150-$200 cheaper than other shops i talked to .
Old 06-23-2009, 07:20 PM
Circle-D's Avatar
That price does seem quite cheap and seems like a stock rebuild. I might suggest something a little stronger. The 2015 converter is to low in my opinion, you can get a 3000 stall for a DD and still be happy with street manors.
Chris
Old 06-23-2009, 08:34 PM
Circle-D Thanks for your time on the phone...
Old 06-23-2009, 09:31 PM
5.0to5.7's Avatar
for that stall for 375 whats the main differences between that and the stage 1 you guys sell? the one for 375 would leave me with cam money but i don't want to sacrifice anything.
