Question: Stall installation
Old 08-15-2009, 06:07 PM
dpeach's Avatar
Default Question: Stall installation
So i did my stall the other day and did all of the correct measurements before i put the tranny back on. When i put the transmission back on and got everything tight, i went to tighten up the torque converter to the flex plate, but there was about an 1/8th inch gap.
When i put the bolts in and tightened it up it pulled the converter all the way up to the flex plate and tightened up.
My question is, did i do something wrong in the install? And if i did do something wrong was i supposed to put a shim between the flex plate and the torque converter?
I started it up and drove it home from my buddies place which is about 8 miles away and everything felt fine, no weird noises or grinding.
So what did i do wrong?
Any help will be appreciated
Thanks, Daren
Old 08-15-2009, 07:16 PM
NHRAFORMULA00's Avatar
Your ok with 1/8 ,you will be fine.I believe anything over 1/4 and you have too use shims or else you pull the converter out of the pump too far.
Old 08-16-2009, 10:18 AM
01ssreda4's Avatar
I agree.....you are fine man.
Old 08-16-2009, 12:02 PM
LS1Tech Sponsor
performabuilt's Avatar
1/8 inch you are good no worries
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-16-2009, 10:42 PM
dpeach's Avatar
Another question, if it is off is there any signs of it? any vibrations or sounds i should be looking for. I'm kind of nervous to drive it because i do not want to blow the trans/converter up. How long would it take for it to go if it was off?
Thanks guys!
Old 08-17-2009, 06:46 AM
Badazz 97 TA's Avatar
Dont be nervous to drive it. You want the converter to pull forward 1/8th inch when you bolt it up to the flexplate. its perfectly normal
Old 08-17-2009, 10:06 AM
Chrome355z's Avatar
Yeah your ok, my yank was a 1/4" away and I threw some 0.125" washers in and cut it down to 0.125" (1/8") clearance. I've got 10k with it like that and no problems.
Old 08-17-2009, 10:12 AM
01ssreda4's Avatar
When you add washers, do you need longer bolts??
Old 08-17-2009, 11:31 AM
98 LS1 SC's Avatar
[QUOTE=01ssreda4;12083154]When you add washers, do you need longer bolts??[/QUOT
It is a good idea to use new bolts when you put a new converter in. My vigilante came with bolts but were too short because I had to shim mine. Got some longer bolts and all was good. Just make sure they are good quality bolts.....Grade 8 or better.
Old 08-17-2009, 01:58 PM
Gatsby's Avatar
Does anyone know what size the bolts are for an unmodified flexplate? (I know some TC's require you to drill new holes).
Thanks.
