Fti srls 3600 stall install.
Old 10-05-2009, 05:27 PM
kinglt-1's Avatar
Default Fti srls 3600 stall install.
Hey guys, I just purchased this 3600 stall. I was thinking about going with a
4k stall, but since I will be spraying, 3600 seems like the way to go. What all is needed to install this besides a tranny cooler? Anything need to be done with the flexplate? The tranny is a stock a4 w/ manual shift kit. I want to do everything possible to help it hold up! Thanks.
Old 10-05-2009, 06:01 PM
1999BlueTA's Avatar
Sounds like you pretty much have everything I changed the fluid/filter and added a deep pan that holds a few extra quarts I don't think a deep pan is needed but I just did it anyway just incase. I also added a Trans Temp Gauge its always nice to know what temp its running at.
Old 10-05-2009, 06:04 PM
kinglt-1's Avatar
How is driveability on your fti 4k?
Old 10-05-2009, 07:57 PM
1999BlueTA's Avatar
Drivability is fine for me but I think any stall this size is going to be a bit loose it takes about 2500 rpm's give or take to keep up with traffic. My tranny never gets any hotter than 180 in stop and go traffic in hot Florida summer heat but I have a 30,000 GVW cooler I love it but some people are more picky than others your 3600 should be little bit tighter though.
Old 10-06-2009, 09:32 AM
gt35built's Avatar
Im running the srls 3600 with a 24k gvw cooler I drive it on the street all day and take highway trips to wisconson. The low str (1.78) will produce less heat that a high str, but i believe if your wanting the best converter for n2o you should have went with a higher str.
Old 10-06-2009, 03:37 PM
kinglt-1's Avatar
well nevermind now, the guy is refunding my money lol. He sent it to fti for inspection and the drum is bent. I guess ill keep shoping around. I really want a good converter for street driving, not to worried about it being optimized for spray. This is a 100% street car, might see the track once a year.
Old 10-06-2009, 05:02 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
I just recieved this converter today and the hub is bad where the pump broke in the trans. I am replacing the hub so therefore the unit will be like new.This is a fault of the trans pump not the converter but I am taking care of it for the customer as customer satisfaction is what we are about. I will extend the warranty to whomever purchases this converter.
King I can also design a converter for the jug for you.!!!
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 10-06-2009, 09:14 PM
kinglt-1's Avatar
Greg
It's a go on the converter Greg! Clint decided he wants to let it go. So I will be calling you in the morning. Great talking to you on the phone today. I appreciate all your help!!!
Old 11-27-2009, 11:04 PM
Dom
Dom's Avatar
Have you by any chance taken the car to the track? I'm really curious as to the results. We have endless Yank and PI times, but very few have LS1s with FTI. I'm looking at a 3600 stall. I'm wondering how this compares to a Yank SS3600. BTW, I'm in Rockford, you go out to any local tracks? GLD or Byron?
Old 04-09-2013, 01:19 PM
Killer5.3's Avatar
FTI has a Hard Hit series of converters that have a higher STR similar to the Yank converters. FTI makes a quality product.
Old 04-09-2013, 02:52 PM
Kingc8r's Avatar
Nice 3.5 year thread bump
Quick Reply: Fti srls 3600 stall install.
