Not going into 1st or 4th... Please help!!
Ok so I just got a service engine soon light. So I run by auto zone and they check the code and say something about cylinoid b stuck opean? Or something. Anyways my car won't shift into first or fourth. How do I fix this
could the cold weather have something to do with it? It's about 3degrees....
Hmm i'm actually having the same problems man but mine is pulling like 4 other codes. Well from what i've seen if solenoid b was stuck open it woulldng give you second either am I correct on that? If it is sol b problem you can get one from napa for $17 and it only cost a fluid change, it's really easy to change one.
Idk if it's been tuned for it or not. I'm assuming yes because it has been dyno tuned. I just bought the car so I'm not sure. How do I remove it from limp mode, and what causes it to go into limp mode??
Mine just went too! It's been freezing here! My tranny was rebuilt 16k and they're not charging me to repair it. I have a stall converter but it never gave this code before, and I dyno-tuned it with the stock converter. They can diagnose it easily at a tranny shop, and just drop the pan to get to it. The tranny shop and my tuner said there wouldn't be a problem with the stall, but...?
Ok replaced the ecm and no change got anything else I can check, i'm exhausted. Solenoids seem good, wirings from trans to ecm seems good, wiring from trans to fuse block seems good, ecm is good. So what else is there in this system that can cause this I can check?
