caution! 1-2 in th350
Hey... I am learning a lot about auto transmissions so I am going to keep asking questions...
Todays question is about the 1,2 shift on a TH350. I was told that no matter how well the trans was built, you did not want to shift to second with the wheels spinning?? Is this in the burn-out box? I never had an issue with a TH400 or even a 4l60e under quite a deal of power break in these type of conditions. I have a trans builder friend of mine that has a TH350 in a 9:90 class bracket Nova. Wheels up guy. He said the guy has a lot of passes on the trans and only brakes stuff when he changes his launch or burnout rountin. Any thoughts? P.S. he never breaks the shafts or burns the clutches.
Location: Your girl's back door giving her the long stroke while you're at work
First I've ever heard of anything like that. I always go first to second in the burnout box and haven't had an issue with my TH350
I had an old Chevy Nova with a built TH350, shift kit, 2800-3200 stall...Putting down around 450 to the wheels, and I never had a problem with it shifting 1-2 while the tires were spinning... Actually....it wouldn't shift in mine at all unless you let off the gas....it was set up all crazy like lol.. But at WOT it would NEVER shift at any speed which I kind of liked because then it was like I was driving a manual... Given, hearing my engine rev to 7500+ RPMS was sometimes scary and probably the demise of the engine, but the transmission never once had any problems... This probably doesn't help though.
I think it is harder on the sprag in a TH350 if you come out of the burnout box in second and let off the gas right when the tires start grabbing. I ease off mine and have never had an issue with it. We need to contact Mythbusters!
your old JW i let rip from 1st on a quick shift to 2nd to the limiter then clicked 3rd and off the brakes and drove outta it
now the ol 6spd i had several 3rd gear burnouts on it back in the day
