Anybody run a powerglide in a heavy car?
Just curious if anybody is running a powerglide in a heavy car, and how does it work?
I know they are usually used for light cars, but figured i'd ask
Look at the overall reduction, a 4.10 rear gear with a TH400 has 10.18:1 launch reduction (not including converter), to get that with a powerglide you will need a 5.60 rear gear to get the same reduction.
Not saying it can't be done, I am pretty sure the editor of Hot Rod has a army green street camaro with a 1000+ hp small block with a glide. youtube search FBOMB camaro....
LS1Tech Sponsor
Metallica,
We build many a glides as you know and run them in real street, ultimate street so on. i would recomend a 400. A glide will definately work with a 3800 lb car but more power would be needed. The glide will be much easier on tire spin if you have more power then this would be benificial.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
