I wish I had gotten a cooler with fan
It's not bad under normal driving but combine hot lapping the car at the track, foot braking with a SS400 stall, on a hot day it got up to 250.
Temp data is from the factory sensor (4L80) and reported by the Compushift controller.
The current cooler is the popular B&M (around 12x8x2") mounted "dope style"
At the track, the hottest I have seen measured from the pan is 190, and it was 90+ that day running a 3200 converter. 250 would have me feeling a little worried. Can you perhaps leave it dope style and place a small fan on the rear side of it?
http://www.summitracing.com/parts/FLD-FHP34109/
Yeah I think airflow is your issue here. My coolers have always been in front of the radiator so airflow is decent when the car is moving. I think a fan would solve your issues.
I have a b&m cooler with a fan on my car mounted behind the bumper cover. Its right behind one of the two holes in the cover. I don't have a bumper under my cover though. Works fine there. Mine is wired up to a switch and I never have to turn it on unless its like 90 out and im driving in town. And I turn it on if the trans get to 190*.
my B&M is the one thats like 11"x11" with the 1/2" pipe fittings-its mounted right behind the front bumper, parl.w/ the ground, mounted to the frame at a slight angle-i usually see temps in the 160-170 range on a hot day
i ran the car friday, i noticed the temp at the end of a pass was 172 degs,
4l80e with a high stall-the trans has the temp sensor built into the trans wiring, but seems to be accurate
they need some kind of airflow, room for the air to go thru also
