TH400 RMVB of choice
Old 04-22-2010, 10:24 AM
vortecyota's Avatar
Default TH400 RMVB of choice
I'm ditching my 4L80E in favor of a 400. What is everyone's reverse manual valve body of choice. I'm considering cost to be important, but not if product quality has to suffer.
Oh yea, its a mud truck, will see 0-1% street use. 5.3 ls6 cam maggie @2500 stall, big tires, low gears.
Thanks... Brint
Old 04-22-2010, 10:39 AM
Gingervitis Addict
slow67's Avatar
Thanks... Brint
Why? Same internal components (for the most part).
Old 04-22-2010, 12:15 PM
vortecyota's Avatar
A few different reasons really. -I already have about a 2500 stall converter for a 400, a good stall for an 80 is a pretty big investment.-I don't need OD.-I want a reverse pattern so I can quickly get to reverse from low and vice versa(yes I will give it adequate time to take gear before mashing down)
Last reason is because I have a clearance problem btwn the ps pump pulley and the steering box on the frame(Toyota truck), so I put a smaller pulley on the pump for clearance. Seemed like a good idea... but after just a few minutes of run time the pump starts raising hell and assist fades. I have been assuming its from overdriving the pump. So I added two coolers and an e fan, only makes it take another min or two to start screaming so no good there.
Sooo.... I am hoping that going to a 400 will allow me to move the engine back enough so that I will have enough clearance to put the oem pulley back on.
Sorry for the long **** reply but you asked for it.
Old 04-22-2010, 12:49 PM
Gingervitis Addict
slow67's Avatar
LOL, yes I did. Since your on a budget, I would get a CKPerformance RVMB. Has the fastest 2-3 shift on a VB that is based on the stock VB.
Old 04-22-2010, 01:02 PM
vortecyota's Avatar
Thanks. Do they have a .com. Sorry I'm pretty new to the performance world.See my join date.
Old 04-22-2010, 01:51 PM
kickassT/A's Avatar
http://ckperformance.com/
Old 04-23-2010, 10:24 AM
cause4panic's Avatar
Griner or ck
Old 04-28-2010, 05:20 PM
SuperSlow02's Avatar
+1 for ck, very fast shifts for RMVB
Old 04-28-2010, 05:34 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
We have all the popular valve bodies in stock as well.give us a call or check out our website. www.fticonverters.com
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
