Lokar 4L60e Trans Dipstick question
whats up everyone...
so my old dipstick tube got crushed and i need to get a new one so i figured why go with a stock one...
found Lokar makes a few but which one to get?
i find it hard to believe there can be great differences between the 4 they offer
whats the difference between firewall & transmission mounted?
here they are on Jegs...
http://www.jegs.com/i/Lokar/625/TD-3...oductId=749848
Best advice I can give you is to go buy yourself a stock one.
You want be sorry you did if you change transmission fluid often.
the lokar 4l60e dipstick is a POS...worst thing I've bought for my car
the measuring dipstick is flimsy plastic that curls up on the end and makes it a pain to get back in, the tube is too small to use any normal funnel, even once adapted it takes forever because you have to pour so slow, the design of the stupid *** nuts where it goes into the trans makes it a royal bitch to get in and out of the case, and in the end its just a piece of shiny metal that draws attention from more important aspects of the engine
wish I had a stock one
I have a Lokar on my 4l60e, I hate it. It is the worst piece I have added to the car. As stated it's too small for a normal funnel (mine did not come with an adapter), it also utilizes a woven cable "stick" with what seems to be a lead fishing weight attached to the end to "measure" the fluid level with.
The problem is that the big fishing weight is too large to get an accurate reading, and very hard to read at all. Not to mention the "stick" is so flimsy half the time you end up whipping fluid all over the motor by the time you are able to finally GET a reading.
That's just my opinion though.
/rant off
/rant off
LOL....
Your arms will go numb from holding the funnel while you are outreached. Lokar dipsticks look real pretty but they are a royal pain in the ***. Go get yourself a stock one.
I have the 36" firewall mounted one I recently installed. It came with the adapter to put on the end of the funnel and it didn't really seem too hard to me to fill it up. I'll take the lokar any day over trying to get a stock one back in after it's been removed lol.
I hate it. Had to use one due to with my engine swap and went with the firewall mounted version. For me I didn't really care that it's so difficult to fill the transmission with fluid. Honestly, it's tedious, but wouldn't be a reason to stay away from it. And yes, I had some trouble getting it into the transmission because I didn't notice the flat spot on the tube the second time installing it (somehow I got it first try the first time installing it?). That reason still wouldn't keep me from buying it.
The reason I hate it is it's amazingly difficult to read how much fluid is in there. The "lead weight" on the end (great analogy from above, sums it up pretty well) does a TERRIBLE job of showing how much fluid you have in your transmission. I typically check the back of the lead weight indicator as it tends to give me better results than the front where the cross-hatch pattern is.
If I had the chance to do it over again, I would've found a way to make the stock one work. It (lokar) does look nice, but it does an awful job at what it's made for, that being showing you the transmission level.
the accuracy of fluid is a problem for me with the stock one anyway do to the cam shaking the **** out of my car lol, just ordered a lokar and if thats the only real problem then its no different than now lol.
