trans question...
Old 09-18-2010, 10:25 PM
tonytone4143's Avatar
Default trans question...
what would be the best converter for a dd and street strip on weekends for the 4l60e? or should i just go with a t56 6 speed?? thanks for any info..
Old 09-19-2010, 08:20 AM
FLT
FLT's Avatar
Tony I would contact one of our converter sponsors to get what you need. Circle D, Yank or FTI are three that come to mind. Vince
Old 09-19-2010, 01:30 PM
Circle-D's Avatar
I would suggest to make a decision on auto or stick. A stalled auto is very fun but some guys just love banging the gears. If you decide on am auto, we have numerous options to pick from. Our 278mm HP Series is a great choice for a near stock DD. Or we can step it up to our Pro Series and make you fly!
Chris
Old 09-19-2010, 01:56 PM
tillery's Avatar
Go for a built auto and a billet convertor from the ones mentioned. I just went thru my fourth M6 now with the viper output shaft this time. My fifth clutch going on six. Just got a lvl 4 from FLT ordered for my truck and if it works with its matching stall I'm swapping over to auto for my F body. As for stall speeds share all info with one of the above and don't cheap out. A good convertor will go for about 800-900. Just like a good clutch will run more. But a auto is more consistent and reliable than a M6.
Old 09-19-2010, 03:27 PM
sweet,that the info i was looking for..thank you so much
i will give them a call and start the shopping..
-Tony
Old 09-19-2010, 03:37 PM
Quick Sh0t xMLx's Avatar
-Tony
FTI has a sale $695 shipped, ordered mine last week
Old 09-19-2010, 04:11 PM
ok so basically the auto is more reliable than the t56??? is this correct??
i just want to make sure its reliable and can handle the hwy race or weekend warrior attempt...
also what about a stall?? which one to use?? i dont want to kill my gas milage on my dd comm
ute to much,but i know i cant have both...any info will help alot.thanks in advance
-Tony
Old 09-19-2010, 04:32 PM
tillery's Avatar
I think so. My latest rebuild with a new clutch cost me around 4000. That's a new PST drive shaft. A good clutch,slave. And a built transmission. Had to replace bellhousing and bearing retainer plate also. Another 400 on top of that. So that's around 4400! Then my truck transmission went so as I shopped around for a trans/convertor combo. Going auto is more reliable and cheaper in long run. Banging gears my seem fun. But it gets expensive fast.
Old 09-19-2010, 04:35 PM
tillery's Avatar
What size of cam and gears you have? What's been done to transmission? Being a DD at least a 3000 stall. And a good auxiliary cooler to help keep fluid cooler and in operating range.
Old 09-19-2010, 04:48 PM
as we speak the motor is stock ls1. i have 3.15 gears in the rear. i am just trying to decide on the trans..and that will determine if i will stroke the motor to a 383.. i just want something that is gonna have the ***** when i need it and still be my reliable dd.
Old 09-19-2010, 04:58 PM
tillery's Avatar
A few of these companies offer one free restall. If That helps any.
Old 09-19-2010, 05:00 PM
not to sound dumb but,what do you mean by free restall?
Old 09-19-2010, 05:03 PM
Squirts11's Avatar
My FTI converter is very tight for street driving (w/ 3.73 gears too), and it'll love the bottle...
Give Greg a call, he'll help spec the ideal converter.
If at any time you change setups (thus shifting your powerband around), you can send your converter back and he'll rebuild/restall for your new application - for free.
Old 09-19-2010, 05:14 PM
tillery's Avatar
No dumb questions. Just alot of stupid answers. Lol. A restall is they change It to say a 3000 to say a 4000. So basically buy from the three mentioned and when You go bigger cam or engine. And instead of having to buy another convertor. Restall current one to meet your needs. And no. Don't do this to a stock one. Internally They are different.
Old 09-19-2010, 07:19 PM
sounds good..thanks guy for all the info and help
-Tony
