when i put into revers the car dies on me
Old 09-26-2010, 04:03 PM
themack56's Avatar
Default when i put into revers the car dies on me
when i put the car into reverse the idle drops real low then dies on me. car also just started to make a small whining noise when it gets to operating temp. it only does it in D. whhen i put in park it goes away.
any ideas?
226/236 110 lsa cam
performabuilt level 2
yank ss3600
fast90 90
Old 09-26-2010, 05:03 PM
themack56's Avatar
anyone?
could the converter be locking or too tight?
i had the converter freshened up by yank late last year before putting it in. But the problems like sometimes dying when i put in reverse were present back then, but only would die sometimes. now its all the time.
Old 09-26-2010, 07:48 PM
LS1Tech Sponsor
performabuilt's Avatar
Have you have the car tuned and i would change the fluid and filter to see if anythings in there ,
Frank
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-26-2010, 07:53 PM
themack56's Avatar
Frank
thanks frank. what could possibly be in there?
Old 09-26-2010, 07:54 PM
themack56's Avatar
Frank
forgot to add the car was tuned and the car was running fine. sometimes the idle would come down real low when i put in reverse, but it wouldnt die.
now every time i put in reverse it dies instantly. also the shifts are weird now. th e1-2 shift feels like its winding up then when it shifts it comes down, then the rpms go up again.
Old 09-27-2010, 10:21 AM
Moderator
jimmyblue's Avatar
There are different settings for some idle related stuff,
for reverse than P/N and D (if I recall, been more than
a few months since I looked at any idle tuning). Maybe
these got neglected.
Old 09-27-2010, 05:38 PM
c6 batmobile's Avatar
It may be your idle airflow. Mine was too low after my cam/stall retune and when I put the car in reverse it would die. It sounds like your tune isnt the greatest.
Old 09-27-2010, 11:51 PM
themack56's Avatar
could be true.
but the car ran fine one day. then all of a sudden it started shifting weird and it would die in reverse.
Old 09-27-2010, 11:54 PM
themack56's Avatar
Exclamation
Originally Posted by themack56
could be true.
i think it might be electrical as well. im changing the alternator, i dont think its charging the car anymore.
Old 09-28-2010, 11:07 AM
shake em off's Avatar
Mine was doing that a few a years ago. There is a switch on tranny that needs to be changed. I forgot exactly what it is called but it takes only a few minutes to change. I think its a reverse solenoid.
Old 09-28-2010, 01:45 PM
Jays_SSZ28's Avatar
Why don't you scan it for codes? It could be the IAC, TPS, and other things that won't set the check engine light.
Just changing parts isn't the answer. About that alternator, what kind of diagnosis lead to the belief that it's bad?
Old 09-28-2010, 07:46 PM
themack56's Avatar
car has been scanned. i have efi live.
because it only does it when its hot and the voltage reads below 12 near the red. when teh car is warm or cold. not on for that long. the voltage is up way above mid point. when its like this it is fine to put in R.
Old 09-28-2010, 07:47 PM
themack56's Avatar
what switch and where is it located?
Old 09-28-2010, 11:18 PM
I had friend change mine. I do know its located on the tranny. I will call him and find out exactly where it is on tranny tomorrow.
Old 09-28-2010, 11:39 PM
Jays_SSZ28's Avatar
The switch is the PSM, Pressure Switch Manifold. It's bolted to the valve body.
I don't know about efilive, I have hp tuners, with that I can scan it and see the switch operating. The switch tells the ECM what gear the transmission is in.
I seriously doubt thats the problem.
Old 09-29-2010, 07:42 PM
themack56's Avatar
i remember logging some files. and i logged to see what gear its in.
it wouldnt know p or neutral when i would put it on it. it stayed at 1 all the. my reverse lights are working. so i dont know what it can be.
Old 09-29-2010, 09:53 PM
Jays_SSZ28's Avatar
The reverse lights work off a switch on the shifter, and thats all that switch does.
Old 09-29-2010, 10:12 PM
themack56's Avatar
Exclamation
so if my car isnt reading my scanner isnt picking up R or p/n. what switch or sensor may be damaged?
Old 09-30-2010, 04:32 PM
Jays_SSZ28's Avatar
The one on the valve body as I said earlier.
Been thinking about this, you might want to measure voltage and get the alternator problem figured out first.
Old 09-30-2010, 08:49 PM
joecar's Avatar
There are two switches:
- the pressure switch manifold on the valve body as Jay said;
- the P/N switch on the selector linkage;
(the P/N switch is regardless of the reverse lamp switch);
the PCM reads both of those, and it uses the P/N switch to select the idle air tables... when selector lever is put in gear (D or R) the load on the engine increases which requires the in-gear idle air tables to become active;
in post #15 you indicated that the P/N switch is not indicating on the scantool... so this appears to be the problem.
Quick Reply: when i put into revers the car dies on me
