Jakes performance Converters anyone running one?
Looking to order a 4l80 from jakes and they offer a coulple of levels of converter, for now its going behind a stock ls1 with a TVS2300, but heads and cam are in the cars future. Anyone have any first hand knowledge? Torn between the Billet (750) and the street/race (500) what worries me is the street/race looks really similar to the tci ones with the poor reputation..
Any Idea what Jakes warrenty is on the 4l80"s?
1 yr warranty on the trans and converter.
Converter depends on your power level and intended usage.
Typically the non-billet is a good choice if you are using a Stage II build. If you need a stronger trans, you also would want to upgrade to the billet converter.
Thanks for the response!
is the lockup clutch in the non-billet any bigger than a stock one?
Do you sell the yolk so I can make my drive shaft work?
And with the non billet converter....can I use my stock flywheel or do i need a 4l80? Do i need a Crank Spacer? I am ready to do this!
The standard converter has basically the same friction surface as stock, it has more material than stock by about .030" and is a woven carbon type material with a special bonding process.
The billet ones obviously have a larger clutch.
I also don't require you buy a converter from me for warranty purposes, etc. So if you have a preferred brand, no hard feelings from me.
Circle-D, Yank, P.I., FTI, etc.
With a custom converter, you shouldn't need any spacers.
After you purchased your trans and converter, how much did you have to spend on the other little things to complete the swap if you dont mind me asking. You can pm me if you like.. And also would like to know about how well the transbrake works/worked if anyone here has one from Jake's.. Thanks
Talked to jake last night seems like a great guy and very open about what he sells and does. I will be ordering a trans from him in the next few weeks (I'm traviling for work and i dont think my wife can move the trans inside when its dropped off! )
Running for about 3 months on my Stg 2.. Couldn't have been happier! S/S converter here. Billet is nice if you have the cash, but not required at most peoples power levels. Swap is cake, just notch the tunnel a bit for the new connector to fit in and everything else is basically the same fitment wise. BMR tranny crossmember makes the swap nice and clean aswell.
Overall I will never go to anyone other the Jake now that I have felt the driveability just cruising down the road and then the perfect, crisp, fast shifts under WOT is just INCREDIBLE! Call and talk to him if you are unsure of what you need. If you don't learn anything within 5min of talking to him then i will be suprised.
Gingervitis Addict
What engin combo/power adder/hp/tq are you running? slicks? is it a level 2 trans? which converter? Thanks for the info! .
The 5.3 will see some boost here shortly.
Drag Radials. I didn't have the brake when I had the LS1, but it ran a VERY consistent 8.15 (3 hot-lapped passes were within .02) off the foot-brake.
Now with a stock 5.3L and 3.0 gears (used to be 3.73) it runs 8.8x off the transbrake. I have beat the hell out of this transmission (I'm hard on my cars) and it keeps on goin.
I don't recall the total, but I switched from a T56, so my costs were higher than most (but also offset some from selling the T56).
Yeah stage 2 (with transbrake). Right now just a stock 5.3 (my LS1 spun a bearing about 3-4 months after the swap, because it was tired/worn out).
My 4L80 transbrake has virtually no effect on the operation of the trans in normal mode.
It only requires you to setup the tune for no upshift commands when in manual low.
This isn't an issue that we've seen on the car OS's but it can be on the trucks.
