Trans fluid in C5 Vette
Old 01-24-2011, 03:05 PM
RENE'S RAGE's Avatar
Default Trans fluid in C5 Vette
I need to replace the trans gasket on my wife's '98 C5 Vette.
How much fluid will it take, from just removing the pan.
Thanks.
Old 01-24-2011, 04:51 PM
Predator T/A's Avatar
about 5 you know how to fill it right...fill it sirst with it off untill it starts poring back out the fill hole. then start it up put it in N and then fill again untill it pors out of the hole again.
Old 01-24-2011, 05:52 PM
No, I really didn't know that or when it was full.
Thanks, my wife will be happy. And me too, LOL, no more bitchin'.
Old 01-29-2011, 02:45 PM
Where the Hell is the fill plug.
I found the drain plug.
Is that the only plug for draining and filling?
Thanks
Old 01-31-2011, 09:11 AM
Jeremy@RPMTransmissions's Avatar
The plug on the side of the pan isn't the drain plug. You remove the pan to drain it fully. Definitely replace the filter while you are in there. The plug on the side is the fill plug. Like stated befor fill it till it runs out, then start the car and fill it in neutral. Then put the plug back in and run the car through the gears on the lift then check the fluid level again and top it off if need be.
Old 01-31-2011, 03:08 PM
I got it changed, what was the big plastic part, it was just kind of hanging there.
Hope I didn't get too much fluid in there.
What do you torque the bolts to?
Thanks everyone.
Old 01-31-2011, 03:17 PM
Thanks everyone.
The plastic part was the filter. Torque spec is 18ftlbs I believe.
Old 01-31-2011, 08:00 PM
I thought that was the filter, but I didn't mess with it.
18 ftlb was what I found.
Thanks again Jeremy.
Old 01-31-2011, 09:42 PM
Moderator
Vince B's Avatar
For pan bolts? I would go with 98-108inlbs. Maybe you were thinking about the fill plug.
Old 02-03-2011, 08:24 PM
Yeah, the manual on my '99 TA said 18ftlb, but when I tried to torque them to 18ftlb, that was way to much. So I just torque them by feel.
So 98-108inlbs is probally about right.
Thanks Vince.
Old 02-03-2011, 09:49 PM
10 ft lbs for the pan bolts
Old 02-03-2011, 10:44 PM
96TransAmboosted's Avatar
C5 vette tranny suck, i bought a matco fluid transfer pump just for those cars.
Old 02-04-2011, 03:50 PM
Yeah, you need a transfer pump for sure. It wasn't bad at all, hell the pan almost fell in my face.
