What is the track to getting this damn top bolt out for our transmisson
Man im pulling my trans & its tough! I got all the bellhousing bolts but the very top bolt.
I have taken 7 1/2inch extensions to get the 15mm socket on that bolt & even just try to turn the extensions with the swival socket on there I cant get any tq on that bolt with out the swival popping off. I have yet to even get the 15mm socket to completely seat & grab properly on the top bolt
What is the best way do get this bolt out & what tools do I need to buy to make this smoother
Loosen the motor mount bolts, remove lid/intake bellows/duct, remove transmission cross-member, allow motor/trans to tilt such that trans hangs down, be careful that nothing gets crushed between rear of motor and firewall...
this should give you enough clearance to reach the top bolt using an long extension and swivel (i.e. from one side of the trans).
Done this many times and the best way for me is taking off the trans crossmember so the trans sits at a angle, use a 30" or 36" extension with a swivel that has some tape on it at the swivel so it moves but has resisitance, I aim it using a flashlight down the extension from behind the output shaft.
The passenger side exhaust sometimes rests on the k member, stock or headers.
And the Y pipe has to be disconnected.
Don't even try to get to it from the top.
A swivel socket works better than a swivel with a socket on it. And one solid extension works better than three or more.
Restricted User
Yea you have to take the exhaust down. You SHOULD NOT have to loosen your motor mount bolts. Disconect everything and all the crossmembers and get a long extension and a swivel and go back by the tellhousing and get it loose. It is a bitch, but you can get it done.
it literally takes 30 second when u do it from the top. i have had to pull ~ 15 of these outta fbods and the only time i tried getting it from the bottom was the first one. and even then, ur not gonna get it back in. lol do it from the top, its easy as pie!
i found the top bolt one of the easier bolts to get out... the 2nd or 3rd bolt up on the drivers side was the biggest bastid of them all... swivel socket got it started but i couldnt loosen it all the way before the swivel socket was hitting the floorboard (even while prying the trans down with a prybar) and had to loosen it with the tip of my finger to get it out. that bolt got lost soon after...
also I used a bunch of short extensions(3"-10") and found that i think it worked better for me then just one long one. With all the short extension you will get and arch that almost follows the trans tunnel and that actually allows you to get a more square shot on the bolt at the top with the swivel. worked great for me.
Well I just took the Intake off! It took like 15 mins to take it off & just got it from the top. It was easy as pie then LOL
Now the next bolt down from the very top Bolt. The one on the Drivers side was NO JOKE! Took me forever. I got it with a swivel socket directly under it & just held the extenesion when I turned it.
Now please tell me putting it back in is easier!
Top bolt removal
Joecar has the right idea. I just pulled a 4L60 from a 98 Trans Am. Drop the trans cross member, take the bolts from the torque arm, use a impact swivel that has a slightly longer shank, put a little tape on the socket to keep it from having too mch wobble, a 36 inch extension with a 3/8 drive ratchet to break it loose then use the air ratchet. I had a wanna be mechanic try it for 45 min before I finally had to take it out. I also used the small flash light to put the socket on the bolt. Good Luck
