help car not moving pinched line
Old 08-04-2011, 09:57 AM
2fresh's Avatar
Default help car not moving pinched line
ok so I did my stall last night go to put it in gear won't move. On installation those lines got pinched that go in the side of the trans took them off from the cooler no fluid is coming out. How would I go about repairing this or find those lines I can't find them any where.
thanks
Old 08-04-2011, 10:07 AM
Heads-Up-Outlaw's Avatar
If there is no pressure in those lines, then most likely you have damaged the transmission pump. That is a very, very, very common occurance. You should take the tranny back out and inspect the pump thoroughly. Do a search here on pumps and converters...
Old 08-04-2011, 10:19 AM
2fresh's Avatar
I did everything it said in the guide is it possible the pump is dead and how bad of a fix is that, air in the lines? low fluid maybe?
Old 08-04-2011, 11:43 AM
2fresh's Avatar
ok taking it to trans shop suggestions while im at it?
Old 08-04-2011, 12:14 PM
What area are you in?
Old 08-04-2011, 02:48 PM
2fresh's Avatar
nc southeast
Old 08-04-2011, 03:10 PM
01ssreda4's Avatar
What method did you use to verify the converter was fully engaged into the transmission and what were your observations?
Old 08-04-2011, 09:52 PM
2fresh's Avatar
did the 3 click method, but when installing the tq bolts the crank was very hard to turn then it finally let loose and continued the install
