Cheetah Shifter in a4 Console
Old 09-09-2011, 04:29 PM
Rpayne41985's Avatar
Default Cheetah Shifter in a4 Console
Does anybody have any pics of cheetah shifter installed in a4 console
Old 09-09-2011, 06:32 PM
RiskyZ28's Avatar
only ones i have left of the old car
Old 09-09-2011, 06:55 PM
02 z/28's Avatar
very nice,how did you bolt it down
Old 09-09-2011, 07:11 PM
RiskyZ28's Avatar
had to weld plate over the tunnel cause it was a manual trans. then kept placing the console over it and shimming it and drilling til i had the placement and height i liked....
worked real well
Old 09-10-2011, 02:53 PM
looks nice thanks alot
Old 09-10-2011, 03:35 PM
anybody else have anymore pics
Old 09-13-2011, 12:26 PM
DadsYellowGoat's Avatar
I have one in an A4 GTO, the car is up on a lift now with everything out from underneath so I will be able to get some good pics when I get home from work, should be basically the same in the F-body tunnel
Old 09-14-2011, 06:08 AM
If you look just under the gauges you will see one of the mounting bolts where it goes through the original floor actually clamping the plate between the original floor, silcone around to seal, simple but worked very good no movement or rattles
Quick Reply: Cheetah Shifter in a4 Console
