TH400 guys inside...post pics of your center console/shifter
Old 10-11-2011, 08:14 AM
midwestjunk's Avatar
Default TH400 guys inside...post pics of your center console/shifter
I currently have a t-56 car. i'm looking to go with a th400. can I re-use my center console? can i keep the shifter boot and all? i'd like it clean and stock apearing. i dont want to hack up the console. i've seen some 4l60e cars that put a th400 and cut the console up pretty bad.
post pics of how your console and shifter looks. help me decide how i want to do this.
Old 10-11-2011, 08:35 AM
MM98's Avatar
Yes, you can use your console & shift boot.. You will just have to leave the aftermarket shifter cover off.. I left my console off & put new carpet down, I really like the way the shifter & cover looks by itself.
Old 10-11-2011, 10:19 AM
SuperSlow02's Avatar
You can use a b&m ratchet shifter and sew the boot around it, plus it will fit in stock location. When i changed to a hurst pistol grip, I just changed the top cover over to an auto style and trimmed it to fit. I'll post up some pics when I get home if you'd like. I'd like to do the no console myself
Old 10-13-2011, 07:29 AM
post up some pix guys!
Old 10-13-2011, 10:13 AM
My bad lol forgot about this.
Can't find any of the old set up with the Ta het shifter and 6spd console. I'd advise against a Rachet shifter though
Old 10-13-2011, 02:06 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
M6 console here with my TH350
Old 10-13-2011, 02:22 PM
Duffster's Avatar
What mine looks like...
Also went T56->TH400. Wish I had a lower gear in the back, but still lots of fun
Attached Thumbnails TH400 guys inside...post pics of your center console/shifter-img_0571.jpg
Old 10-16-2011, 10:14 AM
looks almost stock with the shift boot and everything on there.
Old 10-16-2011, 10:35 AM
Duffster's Avatar
That was my goal I've got the reverse lockout under the leather boot currently and you can't see it's there. Was going to get a 6-speed **** for the top but decided (well not really) several other routes. . . IF I could get a 6-speed shift **** with a button on the side, I would SO be jumping on it!
Old 11-14-2011, 09:38 AM
Post up those pics!
Old 11-15-2011, 10:25 PM
1998MysticZ28's Avatar
bump want to see also
Old 11-16-2011, 01:06 PM
LT1Formula007's Avatar
Here's what I got....
I did a TH400 swap on an Auto car. It was in a 98 Trans Am.
I have a few pictures, But It's also not finished yet. We wanna do something creative with the part that lights up. We removed all the letters (prnd321), and we wanna put a colored screen in there with a logo.
Also, We wanna put a shifter boot in there, where the shifter comes out of the console to hide the shifter... But we haven't got that far with it yet.
Here's what we have now!
TH400 guys inside...post pics of your center console/shifter-b-m-1.jpg
TH400 guys inside...post pics of your center console/shifter-b-m2.jpg
And I also did the T56 to 4L60E swap in my car. I used a factory A4 Shifter from my buddies 98 Trans Am. Heres a few pics of it. I retained the 6 speed console, and it can still pull all the way down to 1st gear and go all the way up into park.
TH400 guys inside...post pics of your center console/shifter-a4-1.jpg
TH400 guys inside...post pics of your center console/shifter-a4-2.jpg
TH400 guys inside...post pics of your center console/shifter-a4-3.jpg
TH400 guys inside...post pics of your center console/shifter-a4.jpg
Old 11-16-2011, 07:31 PM
ls1curt's Avatar
Old 11-20-2011, 10:05 AM
Did u have to make a plate to block off the 6 speed shifter hole
Old 11-20-2011, 10:23 AM
Z28/2002's Avatar
Yes you do
Old 11-20-2011, 11:45 AM
You guys just screwing down some sheet metal or what?
Old 11-20-2011, 12:07 PM
dkbmxer002's Avatar
Old 11-20-2011, 11:35 PM
Here are some pics of the Plate I made. I used a tow away zone sign I had laying around.
The sign was about 3/16" thick. Mild Steel. And when Bolted down, and glued into place with RTV, It wouldn't even budge with a hammer, it's so solidly mounted.
I also wanted to use the factory holes that mount the 6 speed shifter boot, So I had my gf hold the plate in place as i drilled the holes from the bottom of the car. Then used bolts with washers, and 2 nuts on the bottom side to hold the plate in place, and to keep them from ever backing off, I put rtv on the 2 nuts and threds also.
Then coated EVERYTHING around the hole and plate with RTV to waterproof the car from rust or any road debries, or exhaust fumes.
I also took the same sign and cut a piece just big enough to cover the hole for the master cylinder for the T56, and used push-pin style fasteners to hold it in place so IF I ever wanted to go back to a 6 speed, My master would just bolt right back in with no issues. And the same with the factory T56 shifter boot,and etc. The car is completely reversable. Only mod I would have to do is drill the holes larger in the rubber boot for the shifter, and use bolts to hold it in place.
Heres some pics for you to kinda go off of....
TH400 guys inside...post pics of your center console/shifter-4l60e-swap-my-ta.jpg
TH400 guys inside...post pics of your center console/shifter-my-auto-9.jpg
TH400 guys inside...post pics of your center console/shifter-my-a4-swap-9.jpg
TH400 guys inside...post pics of your center console/shifter-my-ta-auto-swap-1.jpg
TH400 guys inside...post pics of your center console/shifter-my-ta-auto-swap.jpg
Old 11-21-2011, 01:10 PM
Anyone running a TCI outlaw shifter with a m6 console? if It fits I may order one.
Old 12-21-2011, 10:05 AM
SLOW30th-TA's Avatar
LT1Formula007 - Do you have thread from when you did the m6 to a4 swap?
Quick Reply: TH400 guys inside...post pics of your center console/shifter
