TH400 Newbie
Old 11-21-2011, 05:15 PM
1320talon's Avatar
Default TH400 Newbie
I'm looking into purchasing a TH400 from a local guy here. The only concern is would I only have to grind off the "ears" on the bellhousing on this transmission. Or do I need to change the bellhousing to bolt on to my ls1?
The guy mentioned it came off of a 70's chevy 2wd pick-up.
Here are the pics from the transmission:
Old 11-21-2011, 08:49 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I cut the ears off my TH350 with a hacksaw, did it the same way on my dad's TH400 before we put it back in his '42 Chevy truck
Old 11-21-2011, 09:09 PM
1320talon's Avatar
So that transmission should be fine to mate it to the ls1 right?
Old 11-21-2011, 11:40 PM
Duffster's Avatar
5 bolts yes...
Old 11-22-2011, 06:39 AM
forcd ind's Avatar
most grind the ears off to clear the headers, some are really tight-you can leave them if you have clear., or tilt the trans to install
Old 11-24-2011, 03:00 PM
1320talon's Avatar
I ended up getting the transmission for $75. I will see what other things I need to change over the t56 in my t/a.
Thanks for the help guys!
Old 11-25-2011, 12:56 AM
FasTimeSS's Avatar
That's not a bad price but you are gonna wanna go have it rebuilt with some goodies like a manual valve body, transbrake and 34 element sprag. Have a builder build it for some power so that it will hold up well.
Old 11-25-2011, 06:20 AM
Duffster's Avatar
you have fun with the conversion... just did it myself...
Old 11-25-2011, 03:14 PM
1320talon's Avatar
fastimess- yeah I figured I would have it looked at and get a rebuilt to hold a little more power, along with that trans brake.
Duffster- What all did you do to the trans. before installation?
