ss4000 to loose!!!!
ss4000 to loose!!!!
I just got my Ss 3600 restalled to a ss4000 y does it feel so loose people where who say they feel the same I dnt like it. And my car lost 2mph and .2 in better weATHER wtf. I will luv to trade anybody wit a ss3600.
Something could be going wrong with the trans. I had a reverse apply pin go out when I changed converters....beats the hell out of my why it decided to crap out when not being used. Not a detriment, just another idea.
Fwiw my built 400 had less then 1000mi on it when it happend
With a 1.8 60 ft on your ss3600 something was wrong then. Its still wrong now. ss3600 should be 60fting in the 1.6xs......A full time slip would help also.
Have you dyno'd your car? That cam should make power up top too, so spinning it higher "may" help. What was the 60ft time with the 4,000?
I'd have to agree with 01ss....something seems wrong overall, at least on the first half of the track. Does the car feel sluggish at all?
It has to do with the fact that his setup sucks. 1.8s on an SS3600 and 1.7s on an SS4000 is garbage. The point is if I had a crappy 60' with one converter and swapped to another one and STILL had a crappy 60' time I would look somewhere OTHER than the converter. What kind of transmission tuning does he have?
What kind of times was your cousin's customer's car running with a 1.52 60'. That kind of 60' would have to put him on the stock internal list if he was just bolt-ons.
He's not concerned so much with the 60' but the fact that it ran slower on the big end even with a slightly better 60'. Transmission tuning doesn't affect 60's.
Here is the Camaro cutting 1.52 60' times and 11.6s in the 1/4 with stock internals. I think his whole setup is QA1s all around, adjustable everything (TQ arm, LCAs, Panhard) BMR kmember with upper and lower CAs. Performabuilt LVL2. FAST 90/90. Also before you say "That's not an 11.6 pass" read the comments. He went 11.6s the same day with tuning.
http://youtu.be/8jPi7AKyYes
