Best tranny for a heavy nitrous car?
Old 05-19-2012, 11:33 AM
94dragbird's Avatar
Default Best tranny for a heavy nitrous car?
What is my best bet to get a transmission to live with a 3700+lb fbody and nitrous? Car is currently cam only and a 150 shot but this winter I'm going to a 370 and at least a 250 shot. Goal is to be,able to daily drive the car(overdrive) and run high 9s. Also what would be a good converter?
Old 05-19-2012, 12:21 PM
LSX-coupe's Avatar
If you wanna stay 4l60 rpm hands down at least level 6.
If more race option a th400 would work from RPM or jakes performance.
If you wanna step up you can do a 4l80 with transbreak from RPM or Jakes performance.
Best converters I would choose Circle D or Coan
Old 05-19-2012, 12:41 PM
94dragbird's Avatar
Im not sure which way to go. I just killed an flt lvl7 with a yank ss3600 last night
Old 05-19-2012, 01:38 PM
JLE58's Avatar
Sounds like 4l80 is the only way to go for you Or send the 60 to RPM they are making 60's hold that kind of power.
Old 05-19-2012, 01:58 PM
deion82's Avatar
A 4l80 if it will see the highway or 400 with a brake other wise.
Old 05-19-2012, 04:16 PM
94dragbird's Avatar
Im thinking 80 since I do alot of highway driving. I thought I had it fixed when I went with flt after trashing 4 others from a local guy. Im just tired of fixing the damn thing
Old 05-19-2012, 09:56 PM
mjs1012's Avatar
At that level an 80 should do pretty good. I'd get a jakes.
Old 05-19-2012, 10:01 PM
Moderator
mrvedit's Avatar
+1.
I participate on other forums and I have read only good things about Jakes Transmissions.
Old 05-20-2012, 12:30 PM
LSX-coupe's Avatar
I would have someone check the auto trans tune. I ran my level 6 rpm in my c5 at 3400lbs but it was a 440 ls7 with tfs235 and a 300 shot it lived till I killed the motor.
My current level 7 rpm transmission held in my 427lsx with TFS 245 and 300 shot making roughly 900 rwhp and 3660 lbs .
Old 05-20-2012, 12:33 PM
slayer performance's Avatar
hands down RPM transmission, they are the BEST.....
Old 05-20-2012, 12:45 PM
soundengineer's Avatar
I'm Running a TCI 6x with no issues in a heavy car with a larger shot of nitrous...
a little bit high priced for some people... but when you consider it is a built trans that will handle 850hp without upgrades, and you can upgrade the Clutch hub and the input shaft to make it good to over 1000 hp....its well worth the money...and it comes with almost everything you need
I spent less than $6000 complete to install...and that included my flexplate and crossmember and hoses and wiring needs
Old 05-20-2012, 07:47 PM
Cam72aro's Avatar
go with an 80 if you want to drive the car on the freeway. I had a 400 and went to the 80 because I like to drive the car and 3600 rpms at 65mph was not good.
Old 05-20-2012, 10:30 PM
94dragbird's Avatar
Im going to see what flt will do about it and go from there. If I kill another I'll go to the 80 for sure
Old 05-20-2012, 11:24 PM
Leeroyws6's Avatar
mad dog! lol
Old 05-21-2012, 03:04 PM
Jeremy@RPMTransmissions's Avatar
What is the problem with your FLT trans? I would check with them and have it checked out first.
Our Level 6 and 7 4L60e transmissions have been taking 700+hp beatings regularly in plenty of heavy cars. We have our Level 6 and 7s in Trailblazer SS, GTOs, full weight f-body verts and an ever increasing number of 5th gen Camaros.
With auto transmissions, most of the time it isn't the sum of the parts as much as it is the builder. They are much like engines. You can put the best parts in the world in them. But if they aren't assembled correctly they will fail every time.
Old 05-21-2012, 03:20 PM
94dragbird's Avatar
Started losing the 3-4 clutch pack. Very sluggish 2-3 shift and slips in 3rd and 4th but the converter does still lock up for now.
Old 05-21-2012, 03:57 PM
How many passes/miles are on the trans?
Old 05-21-2012, 04:07 PM
94dragbird's Avatar
Less than 20 passes/2000 miles
Old 05-21-2012, 07:11 PM
malibutwins's Avatar
700 hp is all relative to the weight of the car or truck. 4l60 you will need more maintance ie rebuilding then a 400 or 4l80 go for the 400 or 4l80
Old 05-21-2012, 07:49 PM
94dragbird's Avatar
I probly will... Im going to start working.on a lighter car to drag and use this one for autox
Quick Reply: Best tranny for a heavy nitrous car?
