Best tranny?
Best tranny?
I am new to this site and was looking for a little info. on a tranny for my 99 Trans Am. I am looking for something that will hold up. Already gone through the 4L60E and it has a TH350 in it now but not working properly. I think that it was not built properly. Looking to possibly go with a TH400 but not sure if it will still be streetable. I run at the track on weekends but also still want it to be a street car. Here is a list of what I am working with.
Lunati 382
Lunati 382
Lunati 382
Lunati 382
Lunati 382
comp cam 230-236 593-602 114
West Coast Performance Stage 3 Heads
TNT wet kit (set at 175)
Around 450-475 RWHP on motor.
Got cut off some how.
Lunati 382
Lunati 382
Any body got any suggestions?
Originally Posted by Gary98Z
You might want to try Rossler. Rossler does the 4l60e's for Lingenfelter LS1 427 twin turbo vettes. His tranny's are very pricey though.
Thanks I have been looking into the TH400, just not real sure about streetability.
Is your 350 full manual? If so...a 400 should be about the same...
Originally Posted by z28hokie
Well, youre TH350 and a TH400 are very similiar. The TH400 is basically just a heavier duty/beafier trans. Neither is lockup or has overdrive...
Trans Brake really puts some strain on the trans when released...
But if it's well built, that doesnt matter- just many rebuilders use a few different/better components in trans brake applications (that dont really matter in a normal application).
Moderator
TH400 and 4L80E are pretty near the same size/weight
and same need for sledgehammer bodywork in the tunnel,
right? Might want to get the OD and adapt it up so the
PCM can run it? A crate GM 4L80E might (?) even have
a warranty, and I think there are a couple of places that
have adapt-'em-up wiring kits. Something to look into,
if you're dead set on beefy.
th400
With th e TH400 does anybody no if I need the short or long tale houseing for the stock drive shaft to work. 99 trans am LS1.
LS1TECH Sponsor
Check out the transmission section of our website. Give us a call.
click here for FLP transmission information
Going with the TH400 tranny, now I need a good shifter. Any suggestions or pics of shifter installed?
Also- getting the trans with a reverse pattern valve body (where you pull back to shift) is nice, need to make sure your shifter matches this.
As for the actual trans, I've heard good things about this shop:
http://www.ckperformance.com/select.html
Also heard great things about FLP, TCI, Hughes, and ATI.
https://ls1tech.com/forums/showthread.php?t=159015
If you hurry, this just might take care of everything you need.
SC-
SC-
