A4 and 4.10 gears users inside please
I have a 200-4r w/transbrake in my car with 4.10's out back and a SS3800E verter and right now 26" ET Streets but soon to be 28" streets or drags. Last year I ran 112mph on street tires in the quarter and since then I have added the NXL kit and I am in the process of getting a H/C package.
My question is will I be able to cross the traps without hitting the rev limiter? I am going to raise the limiter to 6800 with the stock bottom end. Should I go a little higher on the rev limiter?
I really dont want to have to shift into OD, but if I do am I gonna hurt stuff badly?
I am guessing without the h/c I will be trapping around 120ish and with the heads and cam around 135ish (It is in a 93 RX7 so I only weigh around 2900lbs).
I will be at the track in 2-3 weeks so let hear some input.
What do you think? I dont have to many gear options the lowest I can go is 3.9.
Mike
Mike
Output from the calculator on my site Speed vs RPM .
I think you need a numerically smaller gear or a bigger tire.
Code:
Transmission Ratios: 1st: 2.74 2nd: 1.57 3rd: 1 4th: 0.67 Tire Diameter 1: 28 inches Rear Gear Ratio 1: 4.1:1 RPM 1st 2nd 3rd 4th 5th 6th 1000 7 12 19 29 0 0 1500 10 18 29 43 0 0 2000 14 24 38 57 0 0 2500 17 30 48 71 0 0 3000 21 36 57 86 0 0 3500 24 43 67 100 0 0 4000 28 49 76 114 0 0 4500 31 55 86 128 0 0 5000 35 61 95 143 0 0 5500 38 67 105 157 0 0 6000 42 73 115 171 0 0 6500 45 79 124 185 0 0 7000 49 85 134 200 0 0 7500 52 91 143 214 0 0 8000 56 97 153 228 0 0
LS1Tech Co-Founder
Why do I have to log in to use your programs?
I'm running 28x10.5x15 et drags, 2.48 first gear T400, Yank 4500, shift points at 7000, with 750rwhp what gear do I need? I am running a 4.11 but it's too much.
Regarding the gear you need what mph does the car trap at now? Here is the output for you set up, this assumes a 6% torque converter slip.
Use this Calculator for comparing two different gear ratio's.
Code:
Transmission Ratios: 1st: 2.48 2nd: 1.48 3rd: 1 Tire Diameter 1: 28 inches Rear Gear Ratio 1: 4.11:1 MPH RPM 1st 2nd 3rd 4th 5th 6th 1000 8 13 19 0 0 0 1500 12 19 29 0 0 0 2000 15 26 38 0 0 0 2500 19 32 48 0 0 0 3000 23 39 57 0 0 0 3500 27 45 67 0 0 0 4000 31 51 76 0 0 0 4500 35 58 86 0 0 0 5000 38 64 95 0 0 0 5500 42 71 105 0 0 0 6000 46 77 114 0 0 0 6500 50 84 124 0 0 0 7000 54 90 133 0 0 0 7500 58 97 143 0 0 0 8000 61 103 152 0 0 0 Tire Diameter 2: 28 inches Rear Gear Ratio 2: 3.73:1 MPH RPM 1st 2nd 3rd 4th 5th 6th 1000 8 14 21 0 0 0 1500 13 21 31 0 0 0 2000 17 28 42 0 0 0 2500 21 35 52 0 0 0 3000 25 43 63 0 0 0 3500 30 50 73 0 0 0 4000 34 57 84 0 0 0 4500 38 64 94 0 0 0 5000 42 71 105 0 0 0 5500 47 78 115 0 0 0 6000 51 85 126 0 0 0 6500 55 92 136 0 0 0 7000 59 99 147 0 0 0 7500 63 106 157 0 0 0 8000 68 113 168 0 0 0
You can try the quarter mile simulator eDragstrip but the traction algorithm needs some work. It works really well for cars under 350 Wheel HP.
Originally Posted by gator's 99TA
tire growth is an issue too.
My calcs do NOT account for tire growth. I haven't been able to figure out a good growth algorithm. I assume growth is a function of rpm but I have no way to measure it in the real world. Therefore I keep it simple and assume no tire growth.
