Flexplate question 4L80E
Old 06-04-2013, 12:53 PM
MFJ
MFJ's Avatar
Question Flexplate question 4L80E
So I'm starting my M6-A4 swap. My question is which flexplate do I need?
LS1 , 4L80E, 9.5" converter
I have no idea. A regular 4L80E flexplate won't work.
Old 06-04-2013, 01:38 PM
Circle-D's Avatar
Depends on what converter you are using... Do you know what front cover it has?
Chris
Old 06-04-2013, 01:48 PM
MFJ
MFJ's Avatar
Chris
Does this help?
Old 06-04-2013, 03:18 PM
Circle-D's Avatar
That appears to have the LS pilot and is multiple bolt pattern. So you could use the 4L80 setup with the spacer. Or you can use a 4L60 dished type. Do you actually have the converter yet, or is that just from the web? I need you to measure the pilot to pad distance.
Chris
Old 06-05-2013, 05:34 AM
MFJ
MFJ's Avatar
Chris
I don't have it yet. This is the one I was thinking of getting though.
Old 06-05-2013, 07:06 AM
MFJ
MFJ's Avatar
Chris
I contacted them asked for the measurement or recommendationd on a flexplate and the response I got was "Just a standard LS flexplate is all you need." Nothing else, just that.
So from that I should assume a flexplate for a 4L60E would work?
They sent me another email and said a flexplate for an 80E is what I need. All the ones I've seen so far for the 80E are for an 11" converter.
I know jack **** about automatics.
Old 06-05-2013, 10:30 AM
Gingervitis Addict
slow67's Avatar
That cover appears to work with either a 4l60E or 4L80E flexplate setup (assuming it has the longer 4L60E pilot).
Old 06-05-2013, 11:52 AM
MFJ
MFJ's Avatar
Hughes has a SFI approved flexplate. Looks flat though, so I would need a spacer correct?
Old 06-05-2013, 02:40 PM
Mystery Bird's Avatar
I had my converter built to adapt to my stock style LT1 flexplate.
Quick Reply: Flexplate question 4L80E
