Is this trans cooler spot getting enough airflow?
I have my trans cooler pretty much sitting in front of the radiator, and was curious if its getting enough airflow? Cruising around and car up to operating coolant temp, the trans temp was around 168*. But then more "spirited" driving around town and some quick side road passes it would get up to 188*.
So I have a Yank PT4000 converter, radiator is bypassed (stock thermostat), truck trans pan, and a Hayden fin trans cooler. Temp reading are from my Interceptor.
Should I mount the trans cooler more in front so it gets air flow from the lower air dam? Or would it be best to mount it dope style?
Here is how it is:
Here is how it is:
I was testing it out again on some side roads, and the trans temp got up to 210 degrees. I didn't like how close it was to the radiator so I spaced it out further to have more airflow. I need to drive it again and test it out
