3600 or 3800 yank ss converter?
Old 04-23-2015, 08:11 AM
FcoRojas's Avatar
Default 3600 or 3800 yank ss converter?
Hey guys I know this has been covered countless of times but I could use the advice for my specific application.
I felt like it was a good choice to get a 3600ss stall to got with my .231 .239 617/623 custom ground cam
So I called to order the stall and they hit me with get a 3800 since my truck is a regular cab shortbed
I'm going to daily drive her just wondering if it's too loose have a friend who told me I'd burn it up after a while.
Thanks an advance!
Old 04-23-2015, 01:11 PM
farmington's Avatar
put a good cooler on and call it good.
Old 04-23-2015, 01:38 PM
FcoRojas's Avatar
Thats a must isn't 3800 too much for the street though?
Old 04-23-2015, 01:59 PM
high n dry's Avatar
Plenty of guys running ss4000 stalls in street cars... ur good to go!
Old 04-23-2015, 02:38 PM
nj02z's Avatar
Do you think they would recommend the wrong converter to you They recommended a 4000 SS for my wife's car and we could not be happier.
Old 04-23-2015, 05:26 PM
BODUKE's Avatar
If Yank gave the recommendation that's it. For my app Dave recommended a ss 3600 for me. It has worked perfect.
Old 04-24-2015, 06:04 PM
a-low's Avatar
3800 on bolt on daily driver here.
Old 04-25-2015, 12:47 PM
Mike Morris's Avatar
4k at least if you ask me for street cars. The Yanks are very streetable even for a dd
Old 04-25-2015, 01:21 PM
Moderator
mrvedit's Avatar
Just to throw in a different opinion...
Since this is a truck and much heavier than a car, and a DD, I am a bit suspect of such a high stall speed. I had a SS3600 in my car and found it barely suitable for daily driving with a 3.42 rear. When I changed to a 3.73 rear, it was fine.
That cam will make good power by 3000 rpm.
If Yank recommended a 3600/3800 I wonder if you were emphasizing performance and not DD when you talked to them. Clearly a 3600/3800 will give you excellent performance.
Old 04-25-2015, 03:20 PM
SRB02SS's Avatar
Yank ss4000 here and its my daily driver but its currently having a 408 with ls3 topend built and installed. I love how mine drives with the converter.
Old 04-25-2015, 03:44 PM
kinglt-1's Avatar
FTI3800 here...worked great with just bolt on's and even better with h/c/i.
Quick Reply: 3600 or 3800 yank ss converter?
