What kind of shifters do you guys use on a 4L60E?
Old 07-13-2015, 12:15 PM
curtisrp's Avatar
Default What kind of shifters do you guys use on a 4L60E?
Please post the shifter brand name and part number.
Also if you have pictures of the shifter that would be great!
I seem to can't make up my mind if I want to go with a Rossler 400TH or a Rossler 4L60E tranny. But I think I am aiming towards the 4L60E after reading some posts in the forum from some of the guys. Interesting!
Old 07-13-2015, 05:33 PM
nj02z's Avatar
Tci Outlaw. You can switch out the plates for a 2,3,or 4 speed application and it comes with several mounts for the trans cable to trans.
Old 07-13-2015, 06:10 PM
curtisrp's Avatar
Is it possible to install this shifter in the factory console without the cover?
If yes, how hard is it to get the shifter to fit right in the slot hole of the console?
Old 07-14-2015, 02:06 PM
bbond105's Avatar
Most people use the stock shifter and let the PMC or TCM shift the trans.
Old 07-14-2015, 09:11 PM
Bowtiedford's Avatar
my 4l60e came with the TCI outlaw and like it, but went to stock shifter for stock look. Shifter is very well made and designed.
Old 07-15-2015, 11:48 AM
transam69230's Avatar
Old 07-16-2015, 08:27 PM
curtisrp's Avatar
Originally Posted by transam69230
WOW LOOKS NICE! How did you get it out of reverse? There is a reverse leveler at the bottom of the shifter. I am confused, LOL.
Old 07-16-2015, 08:31 PM
curtisrp's Avatar
Yeah I use a stock shifter and let the PCM/TCM shift on its own but when I do a burn out I am not comfortable shifting from 1st to 2nd with a stock shifter. Just afraid I would be in between the gears and not realizing. I don't have time to worry but need a good ratchet type shifter so I can just slap in between gears.
Old 07-19-2015, 11:33 PM
NHRAFORMULA00's Avatar
Start your burnout in 2nd gear. There is no reason to start it in first and then shift into second.
Old 07-20-2015, 11:19 AM
curtisrp's Avatar
That will be the plan next time, LOL. Thanks for the info.
Old 08-02-2015, 02:26 PM
Lavear's Avatar
Anyone have wiring info for B&m shifter.
I have 12v relays one 4 prong and one 5 prong
Can't find any info ...
Quick Reply: What kind of shifters do you guys use on a 4L60E?
