99 4l80 to a l92
Old 09-02-2015, 12:11 AM
916montels's Avatar
Default 99 4l80 to a l92
07 l92 all stock. would i need a different flywheel to connect the 4l80 and l92 together or would the stock flywheel work?
Old 09-02-2015, 06:31 PM
jimmyg's Avatar
You need a flywheel out of something with a 4l80 . Truck, van etc
Old 09-02-2015, 10:54 PM
916montels's Avatar
i pulled the trans from express van with a 454 will that flywheel work? thanks for the help.
Old 09-03-2015, 07:37 AM
JRENIGAR's Avatar
Hard to tell. Pull the flywheel off the engine and see how it fits the converter before puttting them together.
Old 09-03-2015, 05:37 PM
916montels's Avatar
yea i will give it a try before jumping the gun and ordering a flywheel that i might not need..
Old 09-03-2015, 07:36 PM
jimmyg's Avatar
You need one from an ls crank 2500 series pick up with lq4 ,van with lq4 etc. but try it
Old 09-04-2015, 01:38 AM
916montels's Avatar
ok will try thanks
Old 09-07-2015, 02:49 PM
916montels's Avatar
tried to bolt the torque converter to the flywheel but there a big space from the center hub. the flywheel its self only has three holes for the torque converter. is it possible to just drill out the other holes for the torque converter and get a spacer for the hub or just buy a new flywheel? what has other guys done to solve this situation. any part numbers would be great thanks.
Old 09-10-2015, 11:21 PM
jimmyg's Avatar
Go to bone yard or order new flexplate . 02 gmc hd 2500 with a 6.0 should work fine
Old 09-11-2015, 01:06 PM
916montels's Avatar
sweet thanks for the help. does anyone know if the torque converter from a 99 4l80e to a 07 are any different?
Quick Reply: 99 4l80 to a l92
