weight stock torque converter ?
Old 02-01-2017, 11:35 AM
ls1 trex's Avatar
Default weight stock torque converter ?
hi guys
can anybody know who much weight STOCK torque converter for 4l60e gto 2004 ?
or what the better weight for aftermarket torque converter ? ( gto 550hp )
Old 02-01-2017, 11:36 AM
Mappinsj's Avatar
The weight reduction for aftermarket converters usually come from the smaller diameter size
Old 02-01-2017, 12:19 PM
01ssreda4's Avatar
Stock is around 50ish, usually aftermarkets are around 35 or so.
Old 02-01-2017, 02:47 PM
2002BLKWS6's Avatar
Old pic of a 3400 stall i used to run vs the stock converter. Just to give you an idea of size difference.
Old 02-01-2017, 02:50 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
With no fluid in the converters the 11" factory 4L60 converter is 42lbs.
It varies on the manufacturer of the converter but most 9.5" billet 4L60 converters are in the 30-32lb range if they're utilizing a billet lock-up piston like we do in our builds.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 02-01-2017, 03:58 PM
01ssreda4's Avatar
^^^thats correct, the 50lbs I was thinking about was the truck converter.
Old 02-01-2017, 09:11 PM
wht/73's Avatar
Every bit of 50lbs compared to the truck one!
This is a 80E tho
Attached Thumbnails weight stock torque converter ?-torque-converter-size.jpg
Old 02-02-2017, 03:03 AM
ls1 trex's Avatar
thanks guys
Old 02-02-2017, 04:21 AM
Launch's Avatar
The stock converter with fluid can anchor a small boat, that's all you need to know. A good lightweight efficient race converter will transform your car at any speed / rpm.
Quick Reply: weight stock torque converter ?
