cooler size??
Old 03-22-2005, 08:47 PM
Juicedz's Avatar
Default cooler size??
I was wondering what size cooler would work for my application.... TCI 10" USF 4000 with 3.73 gears and I drive minimal city miles (30 weekly). The transmission is a tci th400, also what size coolers is everyone else running and what is the application?
thanks guys
Old 03-22-2005, 09:18 PM
Z28_Ninja's Avatar
i am haveing converter put on soona dn i am going to be running the 24,000 gvw B&M with a vig 3200. in say run the biggest, heat is what kills a lot of trannis so the bigger the cooler the better.
Old 03-22-2005, 10:14 PM
Juicedz's Avatar
thanks, anyone else?
Old 03-22-2005, 10:35 PM
High on diesel fumes
thunder550's Avatar
I don't think you want to to be too cool. The tranny fluid has an optimal temperature range, and if you go below that it will be too thick to protect properly. Not sure what the range is, but something to watch out for. Some of the coolers out there are thermal drop coolers, meaning that the thicker fluid bypasses the heat exchanger until it heats up and thins out enough to drop into it.
Old 03-23-2005, 12:13 AM
Juicedz's Avatar
good input, thanks alot
Old 03-23-2005, 12:28 AM
LFNDUST's Avatar
I have two coolers. Thats because im cool tho
Old 03-23-2005, 12:34 AM
thunder550's Avatar
I just don't want to be that cool I guess.
Old 03-23-2005, 12:43 AM
Juicedz's Avatar
good answers-lol
Old 03-23-2005, 11:33 AM
Ragtop 99's Avatar
150* - 180* is a pretty ideal range to stay in. I would not flog a tranny below about 130* nor would I want my temps to ever exceed 200*
big stall + no lock-up = plenty of heat
get the 24k gvw b&m supercooler
Old 03-24-2005, 06:57 PM
Gregg_98TA's Avatar
B&M 28k supercooler here. I wanted AN fittings so I could go with Aeroquip hoses.
Old 03-24-2005, 09:24 PM
Blacker's Avatar
I am using the B&M 24,000 GVW Cooler and still see 150*-165*.
Old 03-26-2005, 07:33 PM
chevy94c's Avatar
I am using a B&M supercooler 19000 GVW and seem to work pretty good for me.
