vigilante tc ??
Old 05-03-2005, 02:12 PM
warbird27's Avatar
Default vigilante tc ??
may be a dumb question, but what is the difference between a single disc, three disc, and 5 disc? im starting to browse a lil on what torque converter to get, and from what i hear vigilante is the best even though pricey. i still have no idea what stall to get.
Old 05-03-2005, 10:16 PM
warbird27's Avatar
anyone/
Old 05-03-2005, 10:20 PM
Coal Mining Director
onfire's Avatar
A single disk is for lock up at part throttle like a stock converter. A multidisk (I use one) is rated for wide open throttle lockup....which works well for turbos....you can lock up a single disk at wot but it will eventually burn up as it is a wear item.
Old 05-04-2005, 09:39 AM
LS1LT1's Avatar
I don't think you can get the 5 disc versions for stock LS1 F-body applications but you CAN get the 3 disc (both being considered multi disc of course).
Single or multi, all great converters.
Old 05-04-2005, 10:25 AM
warbird27's Avatar
which one do you recommend? or should i look at getting a yank? as you can tell i dont know much about tc.
Old 05-04-2005, 10:59 AM
Yank's Avatar
here is some info
http://www.converter.cc/inventory/GM...al_motors1.htm
Old 05-06-2005, 09:08 PM
Tiger2o69's Avatar
I say get a vig. If you are going to run nitrous of FI get the multidisc if not get the single. IMO when you back up your converter with a 2 year warranty and a free restall you are good. TCI also has good prices.
Old 05-07-2005, 11:26 AM
warbird27's Avatar
i like TCI prices, but i would never get one after my friend and i installed one in his 2000 ta. i've been pretty much set on a vigilante, now i need to figure out what stall to get.
