Tailshaft area squealing???
Hey guys I have a 4L60E in my 94 TA. I put in a aluminum driveshaft from a 98 M6 SS. I put new u-joints in it from autozone. The first time I took it out the front one made noise so I took it apart cleaned it all put and put it back together since the bearings looked fine. I had to much pressure on the end caps and they were pushing against the metal. It was fine for a while.... The other day I heard something like gear whine from under my car. I put it up in the air while checking the rear brakes out. I noticed when i turned the wheels that the car had a high pitch squeal. I thought it was that the u-joint went bad but I didn't have time to look at it.
Today I jacked it up and found out it wasn't the u-joint at all, but the noise is coming from the tailshaft of the transmission. I made sure by taking the driveshaft out and putting a old yoke in there and turning it by hand. It only does it while spinning the transmission in the direction it would spin while going forward. No noise is present while spinning it in reverse. Does anybody know what this is? I did a search and couldn't find anything.
Thanks
Thanks
You could drive it long enough to over heat it, then in turn burn up the tailshaft seal, and run the tranny dry. An extreme circumstance, but, worth consideration.
You WON'T hear it while driving.
Huh I've never heard it before while doing this kind of work on my car. I know I've jacked it up and spun the tires and it was silent. The other day I went over some railroad tracks a little fast and a very very loud pulsing sound and a vibration came from the transmission area. I thought that it went completely. I came to a stop then I started to take off slowly and it was gone.
Then obviously it's a different noise. Remember I CAN'T HEAR IT!
I have a garage floor full of transmissions I can make a video clip of and they all make a Type noise.
