what tranny do i have?
Old 07-11-2005, 04:29 PM
CONVERTED's Avatar
Default what tranny do i have?
95 formula...
Old 07-11-2005, 08:53 PM
csmwiese's Avatar
4L60E Automatic
Old 07-11-2005, 10:10 PM
CONVERTED's Avatar
Originally Posted by csmwiese
4L60E Automatic
is there a difference between that and the 98+? I think they have a 4L80E?
which one is better and why?
Old 07-11-2005, 10:49 PM
csmwiese's Avatar
No, they have the same 4L60E. 4L80E is found in like, heavy duty trucks.
Old 07-12-2005, 09:11 AM
CONVERTED's Avatar
ok then can someone please explailn this..
I've replaced my 95's interior with that of the 00-02's
my console however came from a camaro... it has the following options
P
R
N
OD
D
2
1
my 95 only had the options
P
R
N
OD
D
2
whats the difference?
Old 07-12-2005, 09:42 AM
12secSS's Avatar
You replaced the interior of your 1995 firebird with that of a '00-'02 camaro. Camaros had the option of selecting all the gears with the gear shifter/selector, firebirds did not (IIRC). Although firebirds did have a performance button or something. The 4L60E from the LT1 and LS1 are similar, but not the same. The LS1 has a longer input shaft. The 4L80E was used on 6.0L trucks/SUVs and had similar gear ratios as the TH400, but with a .62 over drive.
You have a 4L60E, which will work with either interior you have. Be sure to use the shifter from a camaro to be certain you can select all the gears. I am not sure if the firebirds had a different shifter assembly.
Old 07-15-2005, 02:48 PM
CONVERTED's Avatar
ah that makes so much more sense now.... thanks for the info.
Old 07-16-2005, 07:58 PM
Pontiacerator
RevGTO's Avatar
You replaced the interior of your 1995 firebird with that of a '00-'02 camaro. Camaros had the option of selecting all the gears with the gear shifter/selector, firebirds did not (IIRC). Although firebirds did have a performance button or something. Be sure to use the shifter from a camaro to be certain you can select all the gears. I am not sure if the firebirds had a different shifter assembly.
I've had two 94 Formulas and they were both 1 2 3 D - same as my 2000. They also had the performance button. You could select any gear manually. I don't think 95's were any different. God knows what that console was.
Old 07-17-2005, 12:37 AM
farsighted770's Avatar
i am actually in the process of doin some work on a 95 4l60e myself, mine was dropped(literally), if you have a good casing i have perfect rebuilt internals... pm me if your interested, i can sell it to you for pretty cheap(i cant use it cuz the bellhousing is cracked)
the problem with the 95 4l60e is that its the only one that will fit in a 95 firebird for the auto tranny setup, you cant use a 93, 94, 96, or 97 cuz they are all very different, the 96+ are all obd2 so the wiring is COMPLETELY different, the 94 you can use if you rewire the torque converter lock up from the harness to the pcm, (from what im to understand). and i think the 93 has a different output shaft setup(but im not sure on that one) anyway, i did a lot of research on the swapping, and your best bet would be to find just a 95 and use that or if your good with wiring get a 94 and set up the harness for your car(thats what im doin with mine right now)
Old 07-17-2005, 12:40 AM
also that little button everyone talks about on here that says perform for the transmission is supposed to be a line pressure control switch, just a boost in the pressure applied to the tranny, for harder, firmer shifts... least thats what i have been told... ????
Old 07-17-2005, 02:47 PM
Pontiacerator
RevGTO's Avatar
No, it was more than that - it activated different tables for shift points, etc.
Old 07-17-2005, 03:06 PM
2xLS1's Avatar
The 2.73 geared LT1s did not have 1 on the selector.
Old 07-21-2005, 05:48 AM
DRTYBRDLS1's Avatar
2xls1 is right, only the 3.23 cars got the 1 option, although its a very easy mod to remove the console cover and notch the shifter and you will have the 1 option!
