Torque converter for V6
Old 09-04-2005, 11:32 PM
NX_CaGEdApE00's Avatar
Default Torque converter for V6
Ok im not much of a V6 guy.. im used to LS1's..
I just happened to pic up a 98 Camaro with a 3800 in it..
My question is what is the biggest, best convertor i can run in this while still being streetable... I only plan on doing ram-air, maybe headers and some weight reduction, maybe a cutout as well...
Are mid 14's possible with this?? OR what should i do...
i plan on swapping an LS1 in within 2-3 years...
Thanks
Dave
Old 09-06-2005, 11:50 AM
anyone...?????????? TTT>>>>>............
Old 09-06-2005, 12:58 PM
Yank's Avatar
Sounds like you are about there!
if you go to a 3.73 a 4000 - 4200 will help
but what is your plans for the car?
Give us at call
775 826 9955 talk to Dave
Old 09-06-2005, 02:35 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'll link Magnus to this thread, he's knowledgeable.
Old 09-06-2005, 04:36 PM
thanks guys... Plans for the 3.8l are to run mid to low 14's without doing heads or cam..
drive for awhile and then in a few years swap an LS1 in..
Also it may be a possiblity that i will run a 50 - 100 shot wet with the 3.8l..
Any help will be appreciates..
Thanks
Dave
Old 09-06-2005, 05:02 PM
CrabhartLS1's Avatar
so basically go until you blow the engine? i can dig it.
Old 09-07-2005, 08:52 AM
Magnus???????? Any Input
Old 09-07-2005, 09:59 AM
Ragtop 99's Avatar
What is the torque curve for the engine?
A converter rated as a 4000 stall behind an LS1 will probably be like a 3500 or less behind a V6. If the V6 torque curve is similar to an LT1's torque curve, a true stall of 2800 - 3200 would be ideal.
