Trans fluid suggestions
Old 09-28-2005, 11:50 AM
AK's WS6's Avatar
Default Trans fluid suggestions
Well guys, I feel like i've done plenty of reading on what trans fluid to use, but I still can't seem to make up my mind Here is what i'll be installing: Yank SS3800, 24,000 b&m cooler and a modded Pro built automatics trans go shift kit. Now I just talked with Yank and they said it really doesn't matter what goes into their converter, but he said they use type F in their trannys. I'm still waiting to hear back from Pro built to see what he suggests because i've been told if you are using a shift kit type F is the way to go, but I want to hear what he has to say. Now it's onto the Dexrons. I knew there was always III, now from reading on here I now know there now a VI, but after calling around to see who has the new VI in stock I found out there is also IV and V out on the market to really toss me through a loop So if you have any personal experiance or suggestions please post them. BTW, I know to stay away from b&m trick shift per jimmyblue Thanks guys!
Old 09-28-2005, 02:36 PM
AK's WS6's Avatar
Also, since peole are picky about what oil filter they use is there a specific brand trans filter that is good to use??
Old 09-28-2005, 03:41 PM
cablebandit's Avatar
dextron III is what i bet he recommends.
Old 09-28-2005, 06:08 PM
AK's WS6's Avatar
Yup!! My mind is pretty much at ease on that now so, anyone have suggestions on the filter brand??
Old 09-28-2005, 06:41 PM
GregWS6&z28's Avatar
Valvoline Dexron/Mercon III, and Advanced filter brand from in the back (came with gasket)
Old 09-28-2005, 09:01 PM
LS1-450's Avatar
Agreed, Dexron III. Don't go to any higher, GM service department explained to me that they are for the newer something or other type of transmissions & are not designed for our tansmissions. I like Amsoil universal transmission fluid or Red line D4. In addition to the standard transmission filter, have found that an in-line magnetic transmission filter removes a lot of the clutch dust that otherwise would gather in the pan.
Old 09-28-2005, 09:13 PM
nikon1999's Avatar
used castrol dexronIII in mine, and mixed in a couple quarts of B&M trick shift to help prevent foaming, and have had great luck with the combo, tranny temps stay real low
Old 09-29-2005, 02:33 PM
AK's WS6's Avatar
Thanks for the feedback guys!! After some calling around to local parts stores I found that there really isn't much of a slection out there for trans filters, all the stores only carried 1 brand and a few of them had a ATP brand so that's what I ended up buying. For the tranny fluid Pro built suggested Mobile 1 or AAMCO Dexron III. I had trouble finding Mobile 1 and had never heard or even seen AAMCO but I found some at Auto Zone so I bought that. Hopefully I'll be posting my impressions of my SS3800 and shift kit by early next week!!
Old 09-29-2005, 10:26 PM
back4more's Avatar
only 2 companies make filters in the world bryco and filtran same owner however bryco is aftermarket chinese so look for a filtran label on the filter
Old 09-30-2005, 03:12 PM
Bill Bowling's Avatar
I just bought some Valvoline Dexron III and noticed it was Max-Life. My car only has 25K on it. Should I use it or take it back??
Bill
Old 09-30-2005, 05:34 PM
spy2520's Avatar
so the new dexron 6 isnt as good as they say it is for new and old transmissions?
Old 10-02-2005, 09:58 AM
Bill
Anyone used Max-Life?
Bill
Old 10-02-2005, 05:50 PM
DeltaT's Avatar
I like the Redline Hi-Temp ATF. It is the equivalent to a Type F. My tranny dropped 25 degrees after changing to the Redline. It is in my built 4L80E.
Jim
Old 10-02-2005, 06:16 PM
Blacker's Avatar
I have been using Valvoline Max-Life Transmission Fluid with no issues. One of those remote filters might be a good idea as well.
Old 10-10-2005, 01:27 AM
todddchi's Avatar
I've got some GM Dex VI sitting here, and it VERY CLEARLY states on the GM packaging that it is preferred for all Dex III applications.
That GM service department is full of ****.
Personally I would stick with Dex III or Dex VI. Search around there are complications and good explanations about why to stay away from trickshift, synthetics, etc.
Old 10-10-2005, 06:29 PM
SSCam99's Avatar
[QUOTE=DeltaT]I like the Redline Hi-Temp ATF. It is the equivalent to a Type F. My tranny dropped 25 degrees after changing to the Redline. It is in my built 4L80E.
I'm glad to hear that! I ordered the Redline Hi-Temp ATF and just got it in today. I was hoping it was worth the extra cash I spent.
Old 10-11-2005, 03:27 AM
SLP 02 SS's Avatar
Tranny Builders WILL tell you to stay AWAY from Synthetic fluids
due to the lack of heat displacement, and that the Synthetics do
not have the recommended Detergents to effectively protect your tranny.
I use the Max Life Dextron III with 2 bottles of Royal Purple.
Works Great and NO PROBLEMS!
Old 10-11-2005, 05:51 AM
Restricted User
Automatics's Avatar
The type of fluid I recommend for the 700R4/4L60E (non-synthetic) is Mobil or Aamco Dexron III. For Synthetics, Amsoil is the best, and then Redline. I have never recommended Mobil One, not that it is bad, i am have not seen good results so far.
Old 10-11-2005, 06:30 AM
Black98Z28's Avatar
x2...i did my filter and gasket when i had the tranny out of the car, also cleaned up the pan...put in some Valvoline Dexron/Mercon III tranny feels great...i hear if u go synthetic its too slipery and the tranny starts to slip.
Old 10-11-2005, 08:13 AM
MARKSZ71's Avatar
i use type f in mine
