Gears on A4 thrown off
Old 11-27-2005, 01:33 PM
2002CobraKiller's Avatar
Default Gears on A4 thrown off
everything is thrown off on my shifter for instance my park is reverse and right in between park and reverse i can feel nuetral, and my reverse is overdrive. its like everything got moved up what do i need to do to fix this i need help asap. TTT
Old 11-27-2005, 02:03 PM
TeamTripp's Avatar
Crawl under the car and take a look at the bracket that holds the shift cable, and see if it came loose. Also see if the cable itself is loose (either at the bracket, or adjustment sleeve).
Old 11-27-2005, 03:08 PM
everything looked in place down there. Could the shifter be causing this because it definitely feels off, but under the console everything also looks in place .
Old 11-27-2005, 03:20 PM
s346k's Avatar
have you dropped the pan and done anything to it? or did this problem blossom out of the blue?
Old 11-27-2005, 03:23 PM
nope never done anything to it. all of my gears are there except park like i said its just like everything got moved up
Old 11-27-2005, 03:51 PM
s346k's Avatar
?? that's odd. i'm no transmission expert, but it sounds like a linkage issue. what else could it be?
Old 11-27-2005, 04:21 PM
im clueless also im wondering about the shifter though because it feels way off
Old 11-27-2005, 09:27 PM
JETBLACK's Avatar
The clip that holds the shift cable in the bracket has poped off. It will look like its in place but when you shift it will come out of the bracket. Turn just your key on dont crank the car and pull the shifter down into gear and then look at it, it will be out of the bracket. A hose clamp works just fine, I've got one on my car right now.
Old 11-27-2005, 09:28 PM
Can you elaborate a little more on this for me JETBLACK please.
Old 11-27-2005, 09:53 PM
JETBLACK's Avatar
Your shifter cable has a bracket it slips into, there is a half moon shaped clip that keeps it in that bracket. When it pops off and you go from park to drive and then back to park it comes out of the bracket and throws off your shifter. Pull your cars shifter all the way down to what should be 1st and look under your car and the shift cable will be out of the bracket. Grab the arm the the cable is attached to on your trans. and manually push it back to park. Then your cable will be back in the bracket and you can put just a hose clamp on it(back side of bracket) to keep it in the bracket until you order that clip from GM. (2.00).
Old 11-28-2005, 10:02 AM
im going to check it out when i get home would this have caused me to lose park because right now my park is reverse like i said its like everything got moved up.
Old 11-28-2005, 01:17 PM
i see that little clip that looks like a staple on the backside of the bracket and mine is intact. What else could it be?
Old 11-28-2005, 04:54 PM
lockdown's Avatar
its the linkage mine did the same thing i had no park.
