What can I do to a 4l60E to make it stronger now?
Old 12-22-2005, 12:24 AM
nomorews6's Avatar
Default What can I do to a 4l60E to make it stronger now?
Mine has 100k miles on it, and I am planning on runnings all bolt ons with a 4000 stall. It seems to shift fine right now, though I think the fluid is dirty. What all can I do to it to prolong the life of it (besides not race )
Also, I am thinking about putting a little spray on later - any ideas?
Old 12-22-2005, 01:02 AM
tbick's Avatar
put a good transmission cooler on it. i just recently put a 24,000 b&m cooler in my car, which has a 3600 stall. im counting on that to prolong the life of the tranny.
Old 12-22-2005, 01:14 AM
nomorews6's Avatar
cool cool - i've heard about a shift kit too. Does that help any?
nomorews6's Avatar
cool cool - i've heard about a shift kit too. Does that help any? If so, how?
Old 12-22-2005, 12:18 PM
VORTECFCAR's Avatar
also interested, have tranny cooler.
Planning on going high stall (~4000). Also planning on throwing a transgo shift kit or the like in it.
Good idea?
Old 12-22-2005, 01:20 PM
ZeeDaddy's Avatar
You will blowup that trans in about 10-20 runs down the 1/4 mile with a 4000 stall convertor. If you are running this on the street, stick to 2000-2800 stall. You will still blow it up soon enough. I run a 2000 stall and it works great with a CAI and complete exhaust system (Headers, high flow cat and Catback). Et's at 12.85@108mph.
Old 12-22-2005, 01:41 PM
monicaz28's Avatar
I wouldn't expect a 100k 4L60e to last a long time at the track...
You'll definitely want to add a tranny cooler. Even though it's not going to help the strength of the transmission, it definitely will prolong the life.
I would just go ahead and save for some good bands and clutches, and have it built right when it goes out. That's what I did.
And a 4000 is great... do you know what str you're going with?
Old 12-22-2005, 02:25 PM
nomorews6's Avatar
I think the str is 2.6
Old 12-22-2005, 02:31 PM
V8_DSM_V8again's Avatar
Run a cooler and maybe aftermarket transfluid and
B&M trickshift
Raptor Blood
Old 12-24-2005, 11:56 AM
kpowr82's Avatar
Don't listen to this guy. Your tranny is gonna take a **** sooner or later with an aftermarket tc regardless of the stall speed. If you want to get the most out of it, get a big tranny cooler and a shift kit. Heat kills a trans, and the shift kit will cause the trans to slip LESS during a shift.
Go with at least a 3200 stall for the street, you will NOT regret it.
BTW, a freind of mine followed the advice above given to him by APE. He put a 2800 1.6str stall in his '02 SS. Both of us had all the bolt-ons except I was still running a stock stall. He beat me by a front fender 3 different times. Two rolls and one dig. After my 3600 stall, I wiped my *** with him by about 5 cars from a dig.
Old 12-24-2005, 08:34 PM
1999 SS's Avatar
i have three questions.
1 what is an str?
2 what would be a good ($)guesstimate on rebuilding an 4l60e for the street using upgraded bands & clutches etc etc without a tc?
3 can the oem tc be restalled to 32-3600 rpm? the reason i ask is that this will be my daily transportation and will never see the track, im just looking for some extra street performance.
Old 12-24-2005, 09:16 PM
Z28_Ninja's Avatar
1 what is an str?
1) depends on tires you will be running and suspension mods (no snese in having the converter with high str if you cant get it to the ground)
2) i just paid 2300 for my tranni build.
3) and i dont think the stock tc can be restalled that high. go with a 3200 vig and you will love it, i have on on my DD and i love it. i put about 38,000 miles on my car in the last 2 years (7,000 since i had the converter put in) and i love it.
Old 12-25-2005, 10:57 AM
kpowr82's Avatar
1) STR stands for Stall Torque Ratio. Basically, it's the ratio by which torque is multiplied from the crank to the trans. The higher the str, the bigger kick you feel off the line because of the multiplied torque. However, the effect of higher str wears off much quicker and less efficient on the top end. Good STR for street tires, I'd say 2.1.
2) Had my Rock-On trans built for 1965 shipped
3) Nope. For a street driven daily driver, I'd recommend no less than a 3400 stall 2.2 str. You'll love it. The higher str will make it feel nice and tight around town. You'll want some drag radials to put the power down though.
Old 12-25-2005, 11:12 AM
SSPEEDY's Avatar
couldn't have said it better myself.
i have a vig3200 (which flashes around 3800). it's great for the street.
i paid 2K for my stage III trans from speed inc (dr evil brand). my stock trans went at 55k miles. i had the converter on there since 32K miles along with a shift kit, tranny cooler. had the cam put in at 40k miles. a ton of track and street passes. trans lasted for a while, i never did more than 2 back to back runs. would always take a minimum 20-30 minute break in between to make it last. finally started slipping on a day when i got a little too confident and did 4 passes in a row.
Old 12-26-2005, 05:53 AM
corvet786c's Avatar
Smile
Just a little info on trannys, I have a friend who has a 99 c5 convertable who has a blower running 11.3 at 119 mph still has stock tranny and stock rear end.Its is his daily driver, dont know how much longer it will last but they do last.
Old 12-26-2005, 08:10 AM
nomorews6's Avatar
corvet786c - I like your sig
Quick Reply: What can I do to a 4l60E to make it stronger now?
