3500rpm 1.7str
Old 01-03-2006, 03:34 AM
nwforever's Avatar
Default 3500rpm 1.7str
i would like the sy3500, but 900 dollars is alot.
if i have fuddle build me a 3500rpm 1.7str converter, should it perform close to the sy3500? low str for a softer hit to the tires and more efficient for a higher trap speed?
Old 01-03-2006, 08:41 AM
12secSS's Avatar
It depends if they build it exactly like Yank does (impeller, turbine and stator design for example). By just spec'ing out the conevter to 3500 stall and 1.7 STR doesn't mean it will act like an SY3500. It may act worse. You would have to let Fuddle know what your intentions are and if they can build it to achieve similar results.
Old 01-03-2006, 09:31 AM
Yank's Avatar
The SY 3500 is a special converter that only Yank builds made with special parts that or exclusive to us offen copied but never matched
it is also one of the converters that is on sale thru the 14th at 10% off
that makes it a great deal.
Thanks for thinking of Yank
Old 01-03-2006, 10:37 AM
1jfuddle's Avatar
In a word...ABSOLUTELY. This is actually a common setup to build, but I usually don't recommend the combination simply because it isn't ideal for streetability. PM sent.
Old 01-03-2006, 10:49 AM
DevonsZ's Avatar
I still trap within 1 mph or the same of my stock stall with my 3600rpm 2.2str Fuddle if thats helps you any. The best with the stocker was 108.xx, with the Fuddle ive hit 107.xx
Old 01-03-2006, 11:05 AM
Yank's Avatar
here is some info on the SY3500 converter, that you might have missed
https://ls1tech.com/forums/automatic-transmission/302569-s-back-super-yank-3500-a.html
Old 01-03-2006, 11:02 PM
Red2000SS's Avatar
I thought you quit making that converter - why is it not listed on your website?
Old 01-04-2006, 09:18 AM
Yank's Avatar
Yes,we still make it!
you have to call on it
and we have many converters for the LS-1 style cars and trucks that are not listed it fact we have over 167 styles of converters and only list the hot sellers at the time, as not to confuse buyers.
Old 01-04-2006, 09:43 AM
dug
dug's Avatar
Id get the vig2800 stall. It actually stalls around 3200rpms and is just as efficient as the SY3500 (according to the dyno at the yank website). Plus its smaller so its lighter. You can find a used vig2800 for less $400.
Old 01-04-2006, 12:48 PM
BubaGumpShrimp's Avatar
i got the 3,800 stall 1.7 fuddle. Feals pretty good compaired to my midwest 3k 2.0 and it will smoke the tires just as easy (nitto 555r's). Down low its a bit mushy with 3.23 gears but of course if you nail it---good bye.. Shift extention for me stays above 5k rpm vs the midwest with a shift extenton around 4,000-4,300.
Old 01-04-2006, 02:45 PM
11 Second Truck Club
MPFD's Avatar
does anyone have any experience with using a stock GM converter out of a 6 cyl envoy? I've read that they will stall between 2700-3500 rpm stock in V8 apps. I would sure apperciate any feedback!!!
