Converter for H/C non-daily driver??
Old 01-15-2006, 06:32 PM
Steve98Z's Avatar
Default Converter for H/C non-daily driver??
Head cam car with a 237/242 595/595, 3.42 stock 10 bolt, this will be a toy so drivability isn't an issue....
Old 01-15-2006, 06:58 PM
yak
yak's Avatar
4000 or a 4200 just hold on and watch that 10 bolt explode!!!!!
Old 01-15-2006, 07:05 PM
Steve98Z's Avatar
Yea I know but I have seen cars run low 1.5x with 4400 stalls on 10 bolts for several years in a row without problems....
Old 01-15-2006, 07:08 PM
yak
yak's Avatar
yeah, know someone who was cam only with a 3800 stall. they ran et streets on the street, and sprayed a 150 shot out of the hole, the car went about 4 feet before the axel twisted and broke into 5 peices.
Old 01-15-2006, 07:14 PM
Steve98Z's Avatar
I'm not going to sit here and argue the reliability of the stock 10 bolt, we all know that at my power level they could go any moment or they may outlast me and you, its coin toss. I'm just looking for info pertaining to the topic i.e stall speed, brand name, personal experience, track times etc etc etc....
Old 01-15-2006, 07:27 PM
Jimmy P's Avatar
Since its not a daily driver, I would say you can go a little higher than that. Possibly a 4500 or so.
Old 01-17-2006, 12:35 AM
FACE's Avatar
What's the dyno look like? I've read a few times, you want the converter to flash a couple hundred rpms below peak torque. That's why I went with a 4400.
Old 01-17-2006, 09:03 PM
JaSSon's Avatar
My 10 bolt holds up to 1.53 to 1.50 60's. The key for 10 bolts is to get a big rear sway bar to prevent wheel hop and a line lock to prevent the death of the posi in the burn out. A4s rule!
Steve, get a YANK PT4000 with that 3.42 gear and a good set of slicks.
Old 01-17-2006, 09:25 PM
The Sad's Avatar
I would give Fuddle racing a call, they will talk to you about the car, your plans, your tolerance, etc and help you pick the right stall. And they are a great price too.
