transmission temp guage
Hope this is in the right forum. Any ways i am going to pick up my trans temp guage today and was wondering, those guys who have them were did you put the sending wire in the trans to pick up the temp? Also will i need anything special to put it in Thanx
Originally Posted by jmm98LS1
There's a port right above the shifter linkage on the driver's side of the tranny. Remove the bolt in that port and replace it with the sending unit. You'll need some extra wire to hook up the power/ground/lighting.
cool, thanx guys i plan on installing it later today just wanted to know whats involved. Sounds pretty easy as far as ground and power i was just going to tap into the radios ignition power wire and ground it on the frame as far as the light goes i was going to tap into the light for the gear selection so i can have the dim feature.
Originally Posted by King James
I take it your not installing it on the pillar by your choice of wiring locations?
Or you can weld a bung into the pan. Or get the temp gauge manifold from Autometer and install it in one of the cooler lines.
Originally Posted by BURN'EM
Because the cooler does as it says cools. the futher away from any heat source the cooler a reading will be. Therefore temp sensor in the Trans will give the most accurate temp of the internals because it's the closest.
Hey guys I got the gauge in and it works great just wondering what temp is normal for these transmissions. I have a 3200 stall and a cooler. I started the car and let it run for 10 min and the gauge was reading like 210 when i shut it off. I also check it with the tech 2 and it said that the fluid was 89 Celsius. So does this mean the gauge is inaccurate?
89*C is 192*F Depending upon where you installed the sensor could make up most of that difference (192-210).
I got a question for some of the other guys if there is a similar place (above linkage) on the th-400?
