Trans brake
Originally Posted by 10.9@1/4
noob question...what does a trans brake do?
Tried to describe in noob terms .
Restricted User
OMG....
Transbrake locks reverse and 1st together, via holding a momentary button to activate a solenoid mounted on the valvebody to reroute fluid internally, once button is released the R is returned to static and you launch violently. A TB will only allow the car to be rev'd up to the stall speed. If you want consistency use a two step in conjunction with TB.
Funny thing is, there are some 4L60E's running around with transbrakes already and they havent popped yet. How long will they hold, I dunno, but they held for more than anyone thought before, which is to say it wouldnt. Kind of reminds me of the whole arguement about STS kits not making any power cuz they are mounted so far away from the header....hmm...I do believe koolrayz has a Rossler built 4L60E w/ Brake and IIRC there are a couple others. Rossler is the only company to my knowledge that has successfully got the TB to work, and on top of that Carl patented it for all the E series transmissions, 4L80E, etc..
