Fuddle Says: 3800/2.2 STR for my 396???
Old 06-29-2006, 05:55 PM
hashtagBMW
Speed Density's Avatar
Default Fuddle Says: 3800/2.2 STR for my 396???
Does the STR seem low for that engine?
Im gona use N2O also but not till next year. Im wondering if thats why such a low STR. Any ideas?
Old 06-30-2006, 09:07 AM
00pewterWS6TA's Avatar
****. id go higher on the stall rpm's also. atleast 4000+.
Old 06-30-2006, 09:18 AM
GregWS6&z28's Avatar
if youll be spraying that stall sounds fine. you probably dont need any more torque multiplication with the big displacement youll have. the lower STR should help your car be a little mroe efficient on the top end of the track
Old 06-30-2006, 09:26 AM
jmm98LS1's Avatar
Exactly what I was thinking. I bet it'll work well with that 396 on the juice.
Old 06-30-2006, 10:01 AM
silverado01's Avatar
that thing should move pretty good w/ a 3800
Old 06-30-2006, 12:38 PM
Honda Hunter's Avatar
I think it will be great. What cam you using again?
Old 07-01-2006, 02:42 AM
hashtagBMW
High 23x/24x 112 LSA, .58x .59x
Old 07-09-2006, 08:55 AM
8banger's Avatar
Haha....I have that exact stall. 3800/2.2. I'm running a cam-only (so far) stock cid LS1, mostly motor, sometimes with spray. I love the stall. The STR is nice because it will launch hard but it doesn't kill your tires on the street. FWIW, I asked for a recommendation for an LT1 setup I wanted to build for my buddy....ported LT4 heads/intake, big cam, and the same stall/STF was recommended. Haha. I guess you shouldn't fix it if it isn't broke.
Old 07-09-2006, 10:10 PM
HD1911's Avatar
what are you gonna rev the engine too anyways?
Old 07-10-2006, 07:38 AM
koolaid_kid's Avatar
One thing to remember, these guys do stalls for a living.
If you are not pleased with it, you can get it restalled for free.
Personally, I try not to second guess the experts.
Old 07-10-2006, 07:49 AM
DAPSUPRSLO's Avatar
What he said
Old 07-10-2006, 10:28 AM
gator's 99TA's Avatar
i have the same stall (or had now that i am going th400).
it is a 3800 behind about 350-400 ft lbs of tq. on the 150 shot it flashed to 4400. i went 1.4 60' with it behind a 3500 lbs car
