tune after converter?
i had a smaller converter but im going to a bigger one, and the car is tuned already but will i have to reutne for a bigger converter?
Originally Posted by performabuilt
yes you will most likley need to retune for proper shift timing ,
performabuilttransmissions.com
Originally Posted by eric01ss
no just dont go wot until u get the shift points done!! also what kind of stall u going with?
Did not get a tune with my converter, a 3000 stall. Run's, shift's just fine.
I have read where with the bigger converters, 3500 plus, that some of them will hit the rev limiter. I don't believe this hurt's the car though, as the limiter just cut's off the fuel at the injector's.
I say put that stall in and see how it works. If your shifting between 5800 and 6000 rpm's your good to go.
