FLEX PLATE INSTALL the spacer
Old 10-26-2006, 09:16 PM
dnkynrbk's Avatar
Default FLEX PLATE INSTALL the spacer
I got the new tci flex plate do you have to put the washer space in the flex plate tried it and it puts my motor in a bind or do you use this spacer at all thanks
Old 10-26-2006, 09:24 PM
blkbird_WS-6's Avatar
What are you using this on? A 4L60E? Th 400?
Old 10-27-2006, 01:02 AM
spy2520's Avatar
i used the spacer and cracked my block and broke the pump in the trans, wasnt paying attention when putting the trans on i wouldnt make that mistake twice.
Old 10-27-2006, 07:33 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
So what you are saying is not to use it?
Old 10-27-2006, 12:53 PM
As long as you are using a LS1 converter you will not need the spacer.
Old 10-27-2006, 04:51 PM
spy2520's Avatar
in fact, if you are using an ls1 converter, you will **** all your **** up once the bellhousing bolts start going in, ask me how i know...
Old 10-27-2006, 10:09 PM
Z28/2002's Avatar
So basically buy a TH350 converter, bolt it to my TCI flexplate and say the hell with the spacer?
Old 10-28-2006, 08:14 AM
Yes, as long as you get a converter for a TH350/LS1 application.
Old 10-28-2006, 03:39 PM
mooreperformance's Avatar
hughes makes a spacer for the sbc converters to work with the ls1 http://store.summitracing.com/partde...5&autoview=sku
Old 10-28-2006, 06:28 PM
spy2520's Avatar
what i mean is the spacer is not intended for LS1s bolting to 4l60Es, mine definitely didnt like the spacer. it is probably there for if you have a different trans or something mating to an ls1, i dont know hwy i didnt ask that question before i tried my install...
Old 10-29-2006, 07:50 AM
IIRC, the spacer is for "old style" converters. They have a shorter "snout" on them compared to the LS1 converters, which have a longer "snout" therefore there is no need for the spacer if you have a verter for a LS1 application.
Old 10-29-2006, 08:38 AM
BTLFEDSS's Avatar
As long as the converter has a LS1 pilot on it you shouldn't need the spacer
BTLFEDSS
Old 10-29-2006, 05:18 PM
"snout" = pilot
That's what happens when I post fresh out of bed. lol
