Power Glide
Power Glide
Ive been looking into TH400s and after talking to alot of people they seem to think a powerglide will do good with my turbo car.Anyone running powerglides and what are you guys doing for converters?? thanx guys
the question is how much does your car weigh. 2800 to 3000 lbs a glide is recomended because you dont need the first gear ratio. since you have a turbo you should seriously consider this, because the turbo requires you to spool up before you really start using it. so if your car is a light car i would say go with the glide at work we have a dragster runs 6.50s runs all year (200 ish passes, glide still runs like a champ and i would def recomend a dedenbear case like 99f1 said). but if you are a heavy car you need the extra gear to let the engine climb quicker so your boost comes in quicker.
Bob, now I see its rated for 2k hp, but I dont get why under the pic it says
"The Proline 2500 adds the unbreakable 1.80 straight cut gears into a stock PG output and carrier, plus a deep aluminum pan to the PL 2000. This increases the rating to 1150 HP. "
Is it a typo or am I just mis-reading it?
A well built 1.76 glide can handle good power. I'm always told 800-900hp. Shaking the tires is the easiest way to break the stock gearset. If you have more power or just want piece of mind, look at Rossler's build sheet for a Terminator 3 powerglide. It adds the aftermarket gearset and everything else needed for WELL OVER 1000hp.
I did a Fuddle converter and it's working great on motor as of now, needs to be tightened for nitrous. Converter selection is more critical when you don't have a steep first gear like a th400 has. Trial and error for me with this one. I think 1000+hp in a 3500lb car will be fine. Even if a 400 was a tenth quicker out of the hole, it will be wilder ride, some say inconsistant, etc especially on a "small" tire. Are you looking to set records?
i just which from a TH350 to a glide, use a TH350 imput shaft so i could use the same verter, (i'm cheap) oh and the car weighs 2580lbs, it takes alwhile to get used to the long 1st gear, don't have to shift until about 1/2 to 3/4th down the track. (1/8th mile) but i am liking ti so far.
