Neutral Safety Switch ????
You could view it by using a scan tool. Or there are some marks on the switch that need to be lined up before you torque it down. I have seen where the switch is worn out from the selector shaft. There is a mark on the main part of the switch along with the insert that rides on the selector, that have to be lined up.
Vince @ FLT, when you guys build your 4L65E trannys for the C5 Corvette, do you guys use that vaccum line mod? If so, once installed in the car, sometimes a code will pop up, it has someting to do with the tranny. What code is that and why does it come up?
Thanks for your time and expertiese.
Originally Posted by charlie c5
So, if the car starts in park or neutral, but DOES start, and won't start in gear, then everything is fine. Right...
