how efficient is the th400 compared to the 4l60?
Old 12-07-2006, 08:31 PM
Houston999's Avatar
Default how efficient is the th400 compared to the 4l60?
Old 12-07-2006, 10:22 PM
LS1Tech Sponsor
performabuilt's Avatar
Well the th400 has a higher mass and a higher reciprocating mass so it should be less efficient
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-08-2006, 12:34 AM
Tech Resident
ChocoTaco369's Avatar
put it this way...
i have no proof, no evidence, i just remember a few months ago, i guy came in here that went from an M6 to a TH400 and lost 90rwhp. granted that was from an M6 and i think he had a heads and cam package, but you'll see a significant drop in horsepower to the wheels.
Old 12-08-2006, 11:08 AM
bjamick's Avatar
Also you lose OD which sucks but you wont break that tranny no matter what you throw at it..
Old 12-08-2006, 11:22 AM
gator's 99TA's Avatar
guys that go with 3 speeds arent too worried about gas milage and efficiency on the dyno
at the track i will take a th400 over a 6 speed in nearly every case. booth et and mph
Old 12-08-2006, 11:57 AM
Zombie's Avatar
It took me 15psi of boost from a T76 to make 470 RWHP on the dyno, but the car goes mid 10's at 130 mph and is 3800lbs.
Dyno's number bragging is for people with slow cars.
Old 12-08-2006, 11:15 PM
revtime's Avatar
In my opinion its the power path and inertia that make the TH400 less effecient.
I can not see how an overdrive transmission can weigh less than a 3 speed, even a TH400.
The ODs case is longer, and there are more parts inside it with the overdrive so the "TH400 weighs more" is not a valid arguement IMO.
Old 12-08-2006, 11:54 PM
Hennytime's Avatar
i never noticed that, a th400 will not only yield better ets(thats a given) but a higher mph as well? any direct gains from a 4l60 to a th400?
Old 12-09-2006, 09:37 AM
SLowETz's Avatar
True, but not convinced about the higher trap. Lower ET but I'm trapping about 4 mph less with the A3 all else unchanged.
FWIW.... I only "lost" 20 rwhp/24rwtq going from an M6 to TH400 w/a steel DS, 4.56's in a 12 bolt on 28" slicks. Not too bad afaik. Granted, this is a LU trans/verter, but still. I can't imagine losing 90 rwhp going from the M6 to A3, but I guess anything's possible under the right conditions-
Old 12-09-2006, 12:22 PM
ls1408cp's Avatar
if you dyno it unlocked it would change your numbers alot
Old 12-09-2006, 12:45 PM
DeltaT's Avatar
Unlocked my 4L80E/Vortech-blown 383 combo made 462rwhp, locked it made 501rwhp. 40HP loss when relying on fluid drive as opposed to a straight mechanical link.
Jim
Old 12-09-2006, 10:23 PM
12secSS's Avatar
The reason the TH400 wieghs more has to do with the beefier components used to keep it together, vs. the flimsly light weight components in the 4L60E that help it with fuel efficiency. Nothing to do really with how many components one has over the other.
Old 12-10-2006, 01:46 AM
LS1Tech Sponsor
The th400is the heavier unit I know I have shipped and handled them , heavier equals more mass to turn equals loss , Though that may not reflect on a dyno because of the way it measures power
__________________
Call 888-744-6542
Old 12-10-2006, 11:25 AM
SLowETz's Avatar
I understand completely..... so I guess a 40-60 rw loss could be considered the norm as Delta's results showed, but 90 rwhp?
Again, I haven't yet dyno'd unlocked, but "thought" it was a valid comparison as the M6 was also a 1 to 1 mechanical link. Trying to compare apples to oranges the most logical way possible to see how the A3 compared to the M6 as far as actual rw power efficiency. I guess my logic was AWOL-
Old 12-11-2006, 09:22 AM
vanillagorilla's Avatar
Jim
That makes sense, you probably had a fairly loose coverter to compliment the blower right. So your converter is about 92% which seems somewhat reasonable.
A 90rwhp loss seems a bit much for just a H/C car. If it were making over 700rwhp I could see that but not for something in the 400rwhp range. I'm willing to bet it had a loose inefficient converter...been there done that.
Old 12-11-2006, 06:34 PM
TNTaddict's Avatar
how can i unlock my Th400?
Old 12-12-2006, 12:08 AM
revtime's Avatar
Your TH400 already is unlocked.
And I still think the 60E is heavier than a TH400.
Someone PLEASE weigh them on an accurate scale dry with no TC so we can find out once and for all the truth.
I would do this myself but even though I have access to the scales I don't have both transmissions side by side to get the answer.
All I have seen is Fedex freight said this or ABF said that or "it just feels heavier"
I have pulled a 60E twice and installed the TH400 in my car and in my opinion the TH400 "felt" lighter.
I have no problem saying I am wrong if I am wrong but so far no one has any concrete evidence.
Even if the TH400 is heavier I would be very curious to see exactly how much.
Sorry for the rant and no I don't know why this bugs me so much.
Old 12-12-2006, 02:31 AM
SuperZ's Avatar
I wouldnt doubt it.My 400 felt as heavy as my T56
Old 12-12-2006, 03:17 AM
TNTaddict's Avatar
i knew we can lock the 4l60e (or any OD trany)....but i got confused when ls1408cp said "
if you dyno it unlocked it would change your numbers alot".....
thx
Old 12-12-2006, 08:28 AM
1320FEVER's Avatar
Quick Reply: how efficient is the th400 compared to the 4l60?
