what do yall think of B&M & Trans Go shift kits etc.?
Old 12-13-2006, 02:36 PM
CaMaRo67RS355's Avatar
Question what do yall think of B&M & Trans Go shift kits etc.?
my friend wants to put a shift kit & converter in his car. it is his daily driver and is just a bolt on car right now. first what kind of shift kit should he purchase in yall's opinion he's interested in the B&M and the TransGo? also should he run the street version or the strip version? what size torque converter & what would be a good brand to buy? should he also change the trans cooler and trans mount while he is doing the shift kit?
thanks
Old 12-13-2006, 03:01 PM
AK's WS6's Avatar
Go with the trans go hands down!!! my car is also a street car, well 95% of the time and I went with 1 washer and drilled the feed holes out per PBA suggestions. As for the converter i'd suggest Yanks SS3600 for him. A cooler is a must and the mount wouldn't be a bad idea while your down there.
Old 12-13-2006, 03:29 PM
what brand coolers and mounts are the best? i only know of a B&M cooler... anymore suggestions?
Old 12-13-2006, 04:09 PM
johnnytransam's Avatar
i just installed a transo go shift kit in mine, i love it, like the lil thump you feel after every shift
Old 12-13-2006, 05:01 PM
LS1Tech Sponsor
performabuilt's Avatar
agreed transgo hands down , but with a couple mods you can contact us about,As for converter I would suggest our PerformaBuilt Precision shift 4000 9.5 stall if the rear ratio is 342-410 and our 3000 to 3500 if its 273 to 355 ratio .I think he would be very happy with this combo
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-13-2006, 05:13 PM
AK's WS6's Avatar
B&M will work just fine.
Old 12-13-2006, 10:18 PM
anyone else i need more help on this im more of the M6 guy myself and dont know much when it comes to making a auto perform better...
Old 12-14-2006, 06:54 AM
ttt for today
Old 12-14-2006, 09:33 PM
74 views and only 7 replies........................................... ...?!?!?!? come on!!!
Old 12-14-2006, 09:37 PM
TA TECH's Avatar
If it ain't built and just put the kit in probably ain't going to last long if ya beat on it much!
Old 12-14-2006, 09:53 PM
wat about if its driven daily and taken to the track every now and then its not a drag car just a bolt ons Z28?
Old 12-14-2006, 10:08 PM
TA TECH's Avatar
A stock tranny can barely take any mods, it may last along time never know but more than likely not.Its a hit or miss thing.
Old 12-14-2006, 10:12 PM
see its his daily driver and he doesnt wanna screw it up he will be easy on it most of the time he was wondering because my other friend has a 98 B4C Z28 with just a shift kit and it was back at the shop a week after he got his shift kit installed cause he broke a band, but he also dogs the **** outta the car.
Old 12-14-2006, 11:00 PM
i talked to my buddy and he said he may wait awhile on a converter is the converter the main thing that will hurt the trans or is the shift kit not a good idea on a stock trans either?
Old 12-14-2006, 11:08 PM
Pontiacerator
RevGTO's Avatar
A Transgo is fine on a stock converter, but personally, I wouldn't bother, because he's going to want to set up the shift kit for the converter once it goes in. He oughta just wait till he's ready to do the converter and then have the **** kit installed.
Old 12-14-2006, 11:20 PM
WhiteStripes's Avatar
Quoted for truth.
But actually adding both these items to the tranny is going to help the longevity of it. Trans go shift kit, Yank SS3600, B&M 24000 cooler, and whatever hell poly mount he wants to put in there. Just do it all at the same time. He'll also want to get the car tuned after that for maximum driveability.
Old 12-14-2006, 11:26 PM
why would he need to get it tuned after doing some trans work? im still learning about all the computer stuff.
Old 12-15-2006, 04:35 PM
LS1 Eddie's Avatar
I like my B&M Trans Pack, it works well. I can't speak for Trans Go because I never had one but the B&M Trans Pack is great.
Old 12-16-2006, 12:17 PM
any other opinions??????? what seems to perform the best shift kit & cooler wise?
Old 12-16-2006, 01:25 PM
lt170chevelle's Avatar
well i have a b&m in mine and a small stall.i drive mine every day and am always playing with the gas. a shift kit regardless will make the trans live longer because of the quicker shifts,and a cooler only helps out more.a stall will get your trans hotter but if you have a good enough cooler it shouldnt be a problem. but yeah if money is a little tight . b&m is the right price , but transgo is a little better..usually has more parts and more involving than the b&m kit,hence the higher price. but thats my view on it
